May 00' 4Runner W/01' transmission parts?
Old 02-10-2008, 10:50 AM
jpmorgan88's Avatar
March 00' 4Runner W/01' transmission parts?
A few months ago I dropped the tranny pan and replaced the oil screen in my trans. When I got the new screen for the 00' model it was the wrong one. I had to get the one for the 01' Same thing with the trans dip stick, I broke that damn thing a while in the process and had to get the one for the 01' because it was the longer one. My Runner was made in 03/00 so why would I need 01' parts? SR5
Last edited by jpmorgan88; 02-10-2008 at 11:02 AM. Reason: I had May instead of March
Old 02-10-2008, 11:30 AM
turboale's Avatar
Are you the original owner?
Old 02-10-2008, 11:31 AM
jpmorgan88's Avatar
No, I bought it with 87,000 on it.
Old 02-10-2008, 11:36 AM
eric-the-red's Avatar
Seems unlikely someone would swap trannies. I know the 01 has a A340F, and I think the 2000 and older used the A340H. Maybe they started switching before the 01 model year. Check the door sticker and see what trans is listed.
Old 02-10-2008, 11:44 AM
jpmorgan88's Avatar
Hey thanks red, I have the A340F. I didn't even know that number was there. So they must have started in 00'. I wonder what the difference is between to two?
Old 02-10-2008, 12:21 PM
pfdaxe's Avatar
My 2000 was Manufactured 04/00 and door sticker list A340E
Old 02-10-2008, 07:06 PM
These are the descriptions from my manual, I think inside they're all the same, but as you've discovered there are some differences in the pan and some external parts.
"The A-340E is an electronically controlled transmission
without a transfer case. The A-340F is an electronically controlled
transmission with a mechanically controlled transfer case. The A-340H
is an electronically controlled transmission with an electronically
controlled transfer case."
Old 02-10-2008, 07:29 PM
Staff
DeathCougar's Avatar
Thats because you have a 2wd. His is 4x4.
If it was SR5 (J-shift pattern) it will have the A340F
If it was Limited (Push button 4wd) it will have the A340H
IIRC all 2001 Trannys were the A340H.
Old 02-11-2008, 06:14 AM
jpmorgan88's Avatar
Yeah that sounds right. Thanks for the input dudes. It makes me wonder how may other parts on my 03/00 Runner are 2001.
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
94whiterunner
09-22-2015 07:25 PM
ACZR
06-23-2015 07:55 PM
WhoahTakeItEasy
Engine Swaps
06-19-2015 02:59 AM
Quick Reply: May 00' 4Runner W/01' transmission parts?
