Master Cylinder a normal problem? 1998 4runner
Old 12-02-2008, 06:08 AM
hkspwrsche's Avatar
Brake Master cylinder- My 98 4runner seems to have a sinking brake pedal but, it hasnt been consistant. Sometimes it holds fine. I havent been trying to push it through the floor but occasionally when holding on a hill it seems to sink further towards the floor than I'm comfortable.
Ive done some searching on master cylinder and this doesnt seem to come up very often. Ive got about 120k miles on it.
So my main reason for the post: Is they something else I should be looking for? I wil be pulling the rear wheels to check for wheel cylinders leaking. Wondering if I should just bleed the brakes and put fresh fluid in to see what happens? I know what happened with my crx is I eventually had a pedal on the floor and and needed a m/c. Getting ready to take atrip and since Im headed to the mountains in the winter I was not planning on taking the s2000.
Thanks in advance
Old 09-19-2012, 06:51 PM
runnermedic's Avatar
hey pal!!!!!
i almost crash today because of the pedal sinking,check my posts
Old 09-19-2012, 07:47 PM
ksti's Avatar
2008 my bad!
Old 09-19-2012, 08:28 PM
Yeah ,im going to do the full breaks service it was a really scary moment
Old 09-20-2012, 03:47 AM
DRCOFFEE's Avatar
Thanks in advance
Pull the ABS fuse and see if it gets better. if it doesn't improve, you have eliminated one part of the system. Check for leaks at the calipers and cylinders. Is the resevior full?
Check the rubber lines from the frame to the wheels. Have someone pump the brakes while you look at each one. If the hose is weak, you may see it balloon under pressure.
Dillon1983
07-07-2015 06:47 PM
shadowbirdie
06-18-2015 06:38 PM
TheManOutside
06-18-2015 03:32 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Master Cylinder a normal problem? 1998 4runner
