Marlin Crawler Chromo Axle Shaft ABS Capable?
Old 11-16-2010, 11:29 AM
chris360hawks's Avatar
I keep having problems with my axle seals leaking and I have replaced the seals countless times, installed one used shaft, new bearings, abs rings, and a new diff breathers. I heard that Toyota upgraded the axles to have larger collars, bearings, and seals due to having problems with them leaking alot. But of course Toyota parts are a arm and a leg to upgrade the axles.
Marlin Crawler sells chromo rear axle shafts that are said to fit a non ABS 4Runner/Tacoma. These shafts are super cheap being $145 for the pair. I talked to Marlin Crawler and they said they sell a "ABS delete" ring that makes the axles fit a ABS equipped ring, but then you lose your ABS capability. My question is, is it possible to press a OEM Toyota ABS ring onto the Marlin Crawler axles that way I can have that baller chromo shafts and keep my ABS? Best of both worlds. Or is there a large difference between ABS and nonABS axles that wouldn't make this possible?
Here is a link to the chromo axles:
http://www.marlincrawler.com/axle/re...oly-rear-axles
Old 11-16-2010, 11:42 AM
waskillywabbit's Avatar
If they would work with ABS don't you think they'd be advertised as such?
:wabbit2:
Old 11-16-2010, 12:26 PM
I would assume so, but when I talked to marlin the guy didn't know if there were differences between the abs vs non abs axle so I thought I'd ask.
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
A2theK
01-10-2016 10:18 AM
Jcrawl94
10
10-24-2015 04:34 PM
delmert
09-30-2015 04:34 PM
ripp96
07-25-2015 02:32 PM
Quick Reply: Marlin Crawler Chromo Axle Shaft ABS Capable?
