Loud shrill on acceleration
Old 09-26-2011, 07:31 AM
mark3406e's Avatar
No problem. Keep us updated. Are you going to fix it?
Old 09-26-2011, 07:38 AM
86yotaswampmonster's Avatar
I would deff check vacuum line. And still check oil filter as well
Old 09-26-2011, 10:17 AM
MLiebal's Avatar
Fix it? I dont know. I'm at 300k and it sits now that I drive 2 hours every day. So probably selling time.
But, I am so curious to what the oil filter look like.
Thanks
Old 10-08-2011, 11:00 AM
MLiebal's Avatar
Well went to the local dealership.
Had to get the tires balanced/rotated (which the dealer has the right adaptors, works great).
The tech said the noise was from the muffler. The damper is split/worn and makes a high pitched whistle/shrill. Guess what, I believe him.
Anyone else hear of this?
With 300k miles time for a muffler!
Will let you know when I change some time in the near furture. Anyone have a good 3.4 muffler they want to sell?
Mike
Old 10-08-2011, 11:41 AM
  #25
mark3406e's Avatar
The only problem I would have with that would be why did the Lucas change the noise? That's a classic sign of a bearing issue.
Old 10-08-2011, 12:49 PM
  #26
MLiebal's Avatar
Sounds a litltle horky. Not sure why, but lucas did seem to help a lot, but not for long.
MAybe I will bolt my daughters 4runner exhaust onto mine. Too much trouble?
Old 10-08-2011, 12:55 PM
  #27
mark3406e's Avatar
I would take a look and see how hard it would be to swap hers onto yours. Did you ever cut the oil filter apart? It's a cheap way to tell a lot
Old 10-29-2011, 02:57 PM
  #28
MLiebal's Avatar
I bought the bosal exhaust ($110). Bolted up, after I cut the muffler off to remove. The tail pipe bolts were welded on. Had to use my angle grinder to remove!
Once installed the noise was immediately gone. Note: just pulling the 4runner into the garage I had the noise!.
How abouit that!
ML
Corvoid
12-11-2015 11:21 AM
Davebarbier
11-03-2015 03:28 PM
Flightguy
10-02-2015 05:34 PM
JPV
09-28-2015 03:15 PM
93RedKrawler
09-25-2015 04:03 AM
Quick Reply: Loud shrill on acceleration
