Location of stock keyless entry module?
Old 12-12-2013, 05:30 AM
aowRS's Avatar
Can someone tell me where this module or box is located?
Andreas
Old 12-12-2013, 07:34 AM
scuba's Avatar
Drivers side kick panel.
Old 12-12-2013, 07:40 AM
aowRS's Avatar
Thanks. Is it marked, or simply the only module behind the panel?
Andreas
Old 12-12-2013, 09:05 AM
scuba's Avatar
I don't believe it is marked. It will have a boat load of wires going to it.
Might say "security" on it or something.
If you're unsure, and it has a part number, look it up on toyotapartszone.com.
Old 12-12-2013, 09:13 AM
TheDurk's Avatar
On my 4Runner, with factory keyless entry, the antenna and receiver part is built in to the Back door ECU and the door control part is built into the Body ECU by the drivers knee.
This diagram for an '02 4Runner should be the same as your '01:
http://tacoma.site40.net/4Runner_96-...ci/033wdlc.pdf
4x4-runner
08-30-2015 08:55 AM
4x4-runner
08-02-2015 09:24 AM
bobpat
08-01-2015 09:25 PM
jetspeedz
07-13-2015 09:32 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Location of stock keyless entry module?
