Led headlight conversion
#61
This is most evident in the width of your output picture. Your output is rather narrow compared to a good HID projector.
Our LED Nissan Leaf has noticeably better headlights than the 4Runner, but the factory HIDs in our Acura TSX are noticeably wider and go farther than the LEDs on the Nissan Leaf. That said, LED technology will only get better.
#62
Our Nissan Leaf has factory LED headlights and they are a simple reflector design, no projector.
I have not purchased LED headlights for my 4Runner yet, and that's partly due to some of the reasons you mentioned--the designs do not appear to be adequately heat-sinked and I figure if I wait another year, LEDs will only become brighter and more efficient.
I guess my point is that LED, HID, and Halogen light sources all have very different properties. A headlight designed for a halogen light source will perform differently if it is changed to an LED or HID light source.
Optics are very complex. So whether it is a reflector or a projector, using a light source not intended for your headlight will result in something less than optimal... MOST of the time.
I think that most people would be best served by upgrading their factory wiring, or using a relay harness running off of the battery, and sticking with some nice halogen bulbs. Otherwise, if you must have something different (like me), doing a proper HID projector retrofit is probably the best upgrade for lighting today.
I do agree with you though; Automotive LED lighting is still very much in its infancy and will continue to get even better
#63
^^ I agree completely with what you said. One of my bigger pet-peeves right now is the increased popularity of HID bulbs in halogen housings. It used to be the Honda Civic guys were the worst offenders, but now it seems to be the Chevy pickups and Tahoes. The glare drives me insane.
#64
I purchased the CREE H4 LED Headlight Kit Light Bulbs Hi/Lo Beam 6000K 9003 HB2 1850W 277500LM. They are awesome but my 98 limited fog lights stopped working and when I turn the fog lights on the high beams come on. I tried a resistor but then the head light stop working all together. Not sure whats going on
live4soccer7
05-11-2016 06:52 PM
Scotttekoch
09-28-2015 10:30 PM
