Latest Cheapest Way to Lift 1997 4Runner Sr5
Old 05-18-2013, 11:19 AM
fibercarbon's Avatar
Exclamation Latest Cheapest Way to Lift 1997 4Runner Sr5
I have a 1997 4runner 3.4L SR5 and my alignment is off said sears"Which i knew because i always have to turn my sterring wheel like 20% a certain way to keep it straight", Sears said "THey cannot perform the alignment until i replace parts they said": i need new tie rods and a few other things i cannot remember, any ideas??
Also i was interested in lifting my truck up 1.5 - 2 inches. what is the cheapest way to do this?
i was looking at
Daystar KT09106BK 2.5" Lift Kit with Bumps and Boots:
Amazon.com: Daystar KT09106BK 2.5" Lift Kit with Bumps and Boots: Automotive Amazon.com: Daystar KT09106BK 2.5" Lift Kit with Bumps and Boots: Automotive
Prothane 18-1701-BL Black 2.5" Lift Front Coil Spring Lift Spacer Kit
Amazon.com: Prothane 18-1701-BL Black 2.5" Lift Front Coil Spring Lift Spacer Kit: Automotive Amazon.com: Prothane 18-1701-BL Black 2.5" Lift Front Coil Spring Lift Spacer Kit: Automotive
what other options or brands do you recommend that dont require changing to much oem parts or cost alot of money..
Ive googled alot but alot of the posts are really old so i wanted to know if there were any updates or newer models or brands of body lifts..
*****THIS IS FOR ON ROAD use,
i wont be tearing it up OFFRoad!!!
THANKS!!!
Old 12-11-2013, 01:26 PM
bump! please help me out here
Old 12-11-2013, 01:31 PM
Swimmerboy2112's Avatar
You can lift it using the spacers as you found out but a better and not much more expensive way would be to use FJ80 Landcruiser springs in the rear and Tundra TRD springs up front.
You could do a body lift as well, that's probably the cheapest way to go.
Old 12-11-2013, 02:54 PM
what is a link to the best body lift kit for a good price?
Old 12-12-2013, 08:21 PM
skoti89's Avatar
google 4crawler. or daystar makes body lifts? search
ball joint spacers are another option
Old 12-17-2013, 06:42 AM
ok so what are the total parts lift i will need if i go with like the daystay body lift?? will i need new shocks or springs? links please!! thanks
Old 12-17-2013, 01:53 PM
vasinvictor's Avatar
http://4crawler.com/4x4/ForSale/Toyo...BodyLift.shtml for body lift. I'd stick with a 1.5" or 2" body. Parts should be around $200.
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Latest Cheapest Way to Lift 1997 4Runner Sr5
