Knocking sound
Old 11-05-2011, 09:04 AM
MJfromMD's Avatar
I believe My T-100 has this noise too
This sounds like the same deal to me. I have a 98 T-100 SR5 4x4 SC 5vz-fe with auto trans.
The knocking metallic noise comes on like a rattle after warm up, but only noticeable at idle. Shifting through gears may temporarily stop noise momentarily, but it resumes most times after a few seconds. Performance etc. seems fine but noise is obviously in need of investigation and remedy.
I am going to crawl under there today and try to get a peek at the converter bolts, etc.
If this get resolved in the meantime, I sure hope someone will post their findings.
Old 11-05-2011, 09:50 AM
terminator's Avatar
Decided not to pull the trans but to run with the noise until I have some kind of failure. Pretty sure the flexplate may be cracked or damaged so I'm going to drive until the trans absolutely has to come out.
Old 11-05-2011, 04:33 PM
j2the-e's Avatar
Have you priced out a new torque converter? If you keep driving with a damaged flex plate, it will damage the converter too. Fix it before it goes boom...
Old 12-15-2011, 03:57 AM
terminator's Avatar
Dealer flex plate and converter are way too much. There is an aftermarket converter but still costs a lot, I have a spare flex plate. I've located a good used trans locally that I'm going to pick up and hang on to until I can either afford to put it in or mine finally gives up and I am forced to have it installed.
Old 01-07-2012, 03:25 AM
  #25
terminator's Avatar
Problem solved!
Well I finally found out what the noise was, a SEVERELY cracked flexplate. I mean so bad that there was only about a 3/8" part in the center area that was holding it together. It was cracked completely around in the center and ready to come apart. I'll get pics when it's light out b/c you have to see it to believe it.
Old 01-07-2012, 07:16 AM
  #26
terminator's Avatar
flexplate pics
OK, here are the pics. I'm assuming that Advance Engine Exchange in Louisville, KY replaced the cracked flexplate when they put the engine in @ 50K ago. I saw it and it was definitely cracked so I wouldn't think that a new flexplate would do this in 50K.
Old 01-07-2012, 07:18 AM
  #27
Texas_Ace's Avatar
Wow, thats scary. I wounder what caused that, misaligned on install?
Old 01-07-2012, 12:46 PM
  #28
jdl25's Avatar
That looks like it had one foot in the grave and the other on a banana peel.
Old 01-07-2012, 01:22 PM
  #29
terminator's Avatar
There's no telling Ace. I have no faith that the shop in KY that installed the engine did anything right other than finding a decent engine. Since then I've had issues with the crank pulley not being properly torqued causing wear on the Woodruff Key which lead to a stuttering at passing gear and now this.
JD, that's the truth! About 3/8" from major disaster.
Old 12-07-2015, 07:10 PM
  #30
Stuckindmud's Avatar
hey all,
I wanted to bring this thread back to life. I have a similar noise coming from my 2002 4Runner, after just doing a timing belt change.
Timing is on point and I have the pictures to confirm the line up.
Obviously yours was the flywheel / flex-plate, is there any way to check that without pulling the transmission?
Old 12-08-2015, 10:08 AM
  #31
terminator's Avatar
Should be able to either pull the starter and rotate the engine, can't remember if there is a lower plate on the bell housing that's removable to get a boroscope up in.
moparbay
03-10-2023 03:50 PM
Anthony Lee Mathis
09-15-2015 07:22 AM
ac7822
09-11-2015 08:49 AM
Streetrod19772000
09-10-2015 06:22 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: Knocking sound
