knock when turning steering wheel
Old 10-20-2004, 07:28 AM
3.4v6's Avatar
i was driving around last night and i noticed that when i turn the wheel left or right i hear this light knocking sound. you can hear the sound in drive and reverse but you can barely hear it in park or neutral. help anyone?
Old 10-20-2004, 08:48 AM
One More Time's Avatar
I had a similar problem with my 2nd Gen. that turned out to be my steering stops.
Old 10-21-2004, 10:25 AM
3.4v6's Avatar
it make the knocking sound when the steering wheel is moved from the level or straight position ... not when it is cranked all the way.
Old 10-21-2004, 10:31 AM
rimpainter.com's Avatar
Check the front sway bar upsidedown "U" mount (passenger side). I had this same problem on my donor rig (96 4Runner) and it turned out to be a bolt that had come loose on the U mount, thanks to the AC drainage landing right on the bolt.
Check it out.
rushw
07-18-2015 01:46 PM
jon.r
07-11-2015 03:34 PM
smiley52
07-11-2015 05:16 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: knock when turning steering wheel
