Key CB and engine dies?
Old 01-13-2012, 04:22 PM
punkelberg's Avatar
I searched and found a thread from 2007....no real answer/solution though.
1996 4runner, TRD Supercharger with the brain in the glove box.
Cobra 40ch CB with a roof-mount magnetic antenna.
CB power is to the battery, ground is to same (-) as my KC lights.
Antenna coax (bought today) goes behind glove box, up door frame and to the roof.
CB is mounted under the stereo.
Works great until I key the Mic...then the engine dies. Hi speed, low speed, no speed.
Any ideas?
Old 01-13-2012, 04:30 PM
scuba's Avatar
Try taking the coax cable away from the ECU.
Old 01-14-2012, 06:30 AM
punkelberg's Avatar
[quote=scuba;51851676]Try taking the coax cable away from the ECU.
ECU being the "brain" in the glove box?
Old 01-14-2012, 10:18 AM
DailyDrive's Avatar
I've had similar issues with other EMI emitting equipment (even not RF transmitters). Threw random codes, idled rough. The solution has been to run both the positive and negative wires directly to the battery.
Old 01-14-2012, 10:32 AM
punkelberg's Avatar
DD, just tried that a few minutes after your post....no luck. Still dies. Going to re-route the coax now.....
Old 01-14-2012, 11:33 AM
punkelberg's Avatar
GOT IT SOLVED!!
Scuba gets the cookie for the win! Re-routed the coax to the drivers side and up to the roof....no more dead truck! Thanks guys for the input!
Old 01-14-2012, 03:03 PM
scuba's Avatar
I think you're just lucky that you didn't completely kill the ECU.
Old 01-14-2012, 03:43 PM
punkelberg's Avatar
Fingers crossed...I only keyed it 4 times. Running good now, should be out of the woods, yea?
sandyota
02-04-2021 11:16 AM
Colington
03-08-2020 09:51 AM
gary4runner
09-24-2015 12:53 AM
Sandman
07-14-2015 12:36 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Key CB and engine dies?
