Just bought 96 4runner sr5...compression test results please help
Old 10-16-2011, 11:55 AM
totally a bro
Staff
vital22re's Avatar
do not make duplicate threads. I will combine your current two.
Old 10-16-2011, 12:30 PM
greenz02's Avatar
Originally Posted by Texas_Ace
The numbers themselves are worthless, ideally you want leakage to be in the sub 10% range. But that gauge is biased depending on how much input pressure you put in.
Listening to it is worthwhile. If it was coming out the dipstick then it is most likely worn/stuck rings. You could try a seafoam treatment and even putting some in the oil, it has been known to help stuck rings.
I would get another compression tester, one with the shortest hose you can use. Then see what that reads.
In the end though, if it runs, then drive it. Don't mess with the motor till it dies. It is usually cheaper to just get another motor vs rebuilding. That why i am not worried about mine, long as it runs, i will drive it.
I would change the oil out for mobile 1. It sucks as an oil but works GREAT as a cleaner. Will clean the inside of a motor to like new. After you run that for a few thousand miles go to a good oil. I like rotella T6 personally. AMSoil is better but costs more.
I am going to go ahead and buy a used radiator and fan and see how it drives. Note taken on the seafoam and mobile 1. Thank you!
Old 10-16-2011, 12:31 PM
greenz02's Avatar
Ok. Thanks.
Old 11-02-2011, 07:38 PM
greenz02's Avatar
Update: New radiator installed and it runs good for having 300k miles. It passed smog the other day and I am now replacing the two rear axle bearings because they were shot! Thanks for the help everyone!
duckhead
170
11-13-2017 06:07 AM
JF9243176
10-08-2017 04:21 AM
CJ94yota
07-03-2015 10:14 PM
saphirekosmos
06-22-2015 10:26 AM
Quick Reply: Just bought 96 4runner sr5...compression test results please help
