installing new tires
Old 08-14-2007, 04:55 AM
johnw999's Avatar
So I've been thinking about buying new tires from ebay. But, I'll probably run into the same problem as I did with my shock and spring install. Most shops won't install the tires if I didn't buy from them, or they want $100 for mounting them. Maybe I should just buy some tire spoons and figure out how to mount the tires myself. Anyone deal with this after buying new tires or rims off the internet?
Old 08-14-2007, 04:58 AM
04 Rocko Taco's Avatar
Kauffman Tire will do it cheap, but stay away from those guys!! They dont pay attention, we used to contract with them for our Mercedes Shop, but we moved contracts!!
Discount Tire if there is one near you, should do it relatively cheap.
Where are you located?
Old 08-14-2007, 10:11 AM
cackalak han's Avatar
Discount Tire and Big O will do it for around $10/tire.
Old 08-14-2007, 11:10 AM
TRDrunner's Avatar
DISCOUNT TIRE.
i went to big o and they charged me 25 a tire.
Old 08-14-2007, 11:26 AM
INFINITY's Avatar
TRUST ME just have them do it and balance them. it is a pain putting tires on rims w/out a machine and takes a while. dont buy new tires (around $500) and f them up putting them on by yourself or running them unbalanced. just spend the $ and do it right.
Old 08-14-2007, 11:50 AM
4Crawler's Avatar
I used one of these (for 33s and 35s):
http://www.harborfreight.com/cpi/cta...emnumber=34542
And with continuous wheel balancers, I am done once the tires are mounted:
- http://www.4crawler.com/4x4/CheapTri...ce/index.shtml
Or if you go w/ some place like Tire Rack, they have affiliated shops where you can have the wheels/tires shipped for local mounting. I did that once on my daily driver, worked fine, I think they ended up charging $12-15/tire to mount and balance on alloy rims.
Old 08-14-2007, 01:07 PM
MLiebal's Avatar
Installing them right means getting the right balance.
For 3rd gen 4Runners (and others) the balancing needs to be done on the bolt pattern, not in the center of the wheel.
Believe it or not, the local Toyota place charged me $40 total starting with the tires in the back of the vehicle. These were nonstock tires.
Give your local dealer a shot!
Old 08-14-2007, 06:28 PM
johnw999's Avatar
Thanks. Toyota of Irving quoted me $99, but I'll call some other dealers and see what they say. Maybe an independent shop can do the job for $40 or $50. I'll keep checking.
Old 08-14-2007, 06:50 PM
aviator31's Avatar
Wal-Mart will do them for about $10 a tire and that includes lifetime rotate and balance. They did a good job on mine, can't complain.
Old 08-14-2007, 07:47 PM
86SR522REEFI's Avatar
yea walmart is cheap but they wont touch aftermarket rims or oversized tires, if your tire dont match your door sticker, they wont touch your tire
BushPig
10-29-2022 06:26 AM
djpg2000
11-11-2020 04:56 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-20-2015 08:31 AM
Quick Reply: installing new tires
