Installed hood struts on a 97 4runner
Old 03-01-2008, 04:06 PM
toytech76's Avatar
I got ambitious this weekend and did something I have wanted to do for awhile. I went to mst recycling (ranchotoyotatruck) and got a set of 95 landcruiser hood struts to use on my 4runner. It was pretty easy to install tho it wasnt a direct bolt in. Each fender has threaded holes for the lower end of the strut but you need to drill out a second hole for the tang to sit in. The upper part was more of a challenge to mount. First I made some mounts to weld to the hood but after tacking one on and trying it, I found it didnt work too well. I decided on drilling a hole through the hood rib and drilling a second larger hole underneath that so I could get my finger in there and slide a nut up to the hole for the strut. That worked great tho I do now have a few extra holes in the hood rib from trial and error. It doesnt matter since I am getting a scoop hood in a month or so. Now I know how to mount them right. The whole thing cost me $50 and about an hour
Old 03-01-2008, 04:09 PM
904_runner's Avatar
looks good! is ranchotoyotatruck a good place to get parts? Ive been to TAP and they were good
Old 03-01-2008, 04:10 PM
toytech76's Avatar
Yep. Ive gotten my 00 runner headlights and the hood struts from him. Always better prices than TAP
Old 03-02-2008, 09:46 PM
Ritzy4Runner's Avatar
I started the same project on my 98 only I used the rear lift gate struts which have a pre-bend in them that line up with the hood excellent. Only problem is one of them got damaged so I only have been able to install one but it works FANTASTIC, no real modifications and I can use one of the 10 mm bolt locations on the insdie fender, then used 1/8th inch rivets, cut 1/8 inch vinyl tubing like from aquarium air line to make a bushing, drill the hole for the pop rivet and voila! So I'm still trying to find another Land crusier (90-97) but nothing around here at all and I do not want to pay outwards of $50 bucks for the thing, heck this one only cost $5. When I get the second one I am going to do a write up showing what I had to do. this is really such a simple mod and really does work and is useful. Was nice this weekend working on my lights and not having to fight the support rod!
Old 03-03-2008, 12:52 AM
Adam F's Avatar
Every vehicle should have hood struts.
Why does it have to be a land cruiser? Other rigs have hood struts. I think Avalons did. Some older Camrys. Mid 90's Chevy trucks.
Old 03-03-2008, 04:43 AM
toytech76's Avatar
Nice looking install ritzy! I wanted to use land cruiser stuuff knowing the hoods on those are heavier and knowing I would get heavier duty struts and they would be cheaper out of an older vehicle. I'm sure highlander or other vehicle struts would work too
Old 03-03-2008, 05:22 AM
zlathim's Avatar
Smart guy. Camry hood struts might work ok, but no way they are as heavy duty as the struts for a heavier hood.
Old 03-03-2008, 11:13 AM
MTL_4runner's Avatar
Very nice job......I hate that darn support rod too.
Definately on my to-do list.
Old 03-03-2008, 11:36 AM
aviator's Avatar
FWIW Jason Burtman (a member here) has a hood strut kit for all the Toyota trucks that features your choice of three different struts a basic model, a mid-level model, and an all stainless steel model. The kit includes detailed instructions his website includes a link to a well done step-by-step pictoral of an installation. The price was very reasonable as well.
His website is www.burtmanindustries.com .
Here is the direct link to the hood lift page. http://www.burtmanindustries.com/zoo...hoodlift_96_02
Link features 1996-2002 4runner but Jason tells me he has install instructions and a kit for all Toyotas.
Hope this helped Aviator
Old 03-03-2008, 12:18 PM
toytech76's Avatar
I saw those after I did this and saw they wernt much more. I think they were about $70. Nice looking kits and a much needed upgrade for anyone with a prop rod
Old 03-05-2008, 10:18 AM
Jason B's Avatar
Yep, I have the above kits in black and even stainless. They are pretty simple to install and in stock.
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Installed hood struts on a 97 4runner
