Ignition cutting out - 3RZ 2.7L
Old 06-30-2016, 02:13 PM
gratpj's Avatar
Hi everyone.
Symptom: engine seems to completely die for less than a second at a time (ignition cutting out?), like a severe stutter, causes quite a lurch/jolt at speed
Frequency: seems to depend on heat -- on short drives and some cooler short trips, it won't even happen at all, on long road trips, once the engine has been going a while it will cut out once every few minutes
Could just be anecdotal, but it seems like moderating the throttle helps prevent the problem somewhat. Might be unrelated, or this could be a key to the solution!
I posted about this in the past, and turns out the truck was in big need of new plugs, which made the problem appear to go away, but actually, it just lessened the problem.
I cleaned the MAF sensor, put in new plugs and wires.
It was suggested to me by a friend that the camshaft position sensor or crankshaft position sensor could be culprits, but I'm looking for other ideas before I start replacing parts that don't need replacing.
I don't think any error codes are being thrown, but I have a cheapo code reader, I can check again.
Ideas GREATLY appreciated!
Old 08-04-2016, 08:04 AM
gratpj's Avatar
Bump. Anyone have some insight? Thank you!
Grego92
02-06-2016 12:10 PM
shisha1999
02-04-2016 12:17 PM
Toyota Punk
07-01-2002 05:44 PM
KLF
06-11-2002 09:23 AM
Quick Reply: Ignition cutting out - 3RZ 2.7L
