IAC Valve or IACV Inspection and Testing
Old 12-10-2009, 10:25 AM
ubermoto's Avatar
So I have a question about the test for the IAC Valve (aka IACV) inspection procedure listed in the FSM (see attached image).
My valve is responding to the voltage (opening and closing), but it is not closing all the way... There's about a 2-3mm gap when it should be closed. Does this mean that it fails the test? Is it supposed to close all the way?
I've already cleaned the heck out of it. Is there a way to adjust where it stops? I have not tried to disassemble it, but it seems like I read somewhere that if you took the plate off the back-side (opposite the green plastic where the harness plugs in), you could make an adjustment...
Thanks a bunch!
Cheers,
Jeremy
Attached Thumbnails IAC Valve or IACV Inspection and Testing-iac_inspect.jpg
Old 12-10-2009, 10:46 AM
okie81's Avatar
A small gap is normal. You can't adjust it though, as it is controlled by the ECU.
Old 12-10-2009, 11:15 AM
ubermoto's Avatar
Here's where I read that it could be adjusted:
http://www.ultimateyota.com/smf/inde...30618#msg30618
Old 12-10-2009, 08:33 PM
ubermoto's Avatar
Anybody else care to weigh in here???
smthwsn357
05-01-2024 07:28 AM
Blamalam
03-12-2022 07:34 AM
wafoogalla
11-02-2016 11:02 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
jjrbus
07-19-2015 02:06 PM
Quick Reply: IAC Valve or IACV Inspection and Testing
