IAC vaive flow direction?
Old 09-03-2003, 10:44 AM
Supercharged's Avatar
I know that this has been discussed before, but I am still a little confused about which way the flow goes. My valve did not come mark as illustrated in the manuel, so I took a guess that the flow goes from throttle body towards the manifolds- not the other way around. Am I right or wrong?
Thank you for your inputs.
Old 09-03-2003, 01:42 PM
White SR5's Avatar
TB to engine
You're right. It should open when air flows from the TB to the engine. Close when air comes from the engine. I had a similar issue, only I just didn't have the IAC check valve and picked up a PCV valve from Pep Boys. Works fine.
Zach
kawazx636
10-06-2021 03:03 PM
Steven.m.paulk
06-07-2020 10:45 AM
live4soccer7
05-11-2016 06:52 PM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: IAC vaive flow direction?
