I want to upgrade my 3.4L
#41
Well i have a 2nd gen 4runner amd want to upgrade.My problem is similar too 3.4 with supercharger or 4.0. Both has the similar power.Only thing i am not sure which would perform better at higher altitude?I heard super/turbo charged engines are better...
Any idea?
Any idea?
#44
Only turbocharged engines are able to dynamically increase their boost to make up for changes in air density due to altitude.
#46
Technically speaking, a supercharged engine is affected by altitude just as much as a naturally aspirated engine, unless you put on a smaller overdrive pulley at altitude. The supercharged engine just has more power to start with.
#47
In theory, he might be ok as long as the ambient temperature is low enough. But you'd have to keep an eye on EGT's and ping because even at high altitudes if it's 80 degrees outside a 2.0" pulley might push your CDT to high and cause ping, high EGT's, and other trouble. That, and a smaller pulley spins the supercharger a lot faster, compromising the overall life of the rotor bearings.
#48
there are some reasons why people PING in some areas and in others they do not...
1. Higher altitudes means you can run lower octane
2. Texas (Ace and Myself) are in the greatest country--err I mean we are close to sea level so we need higher octane
3. The 1uz is a torque motor (as used in the LS400..etc..)
4. An LS1 is small and compact and light and efficient
But if you want to stay with the 3.4--think about cams, Manely high flow valves with polished and down sized stems, Headers, properly designed exhaust system, balancing the rotating assembly and intake matching---and if you are not worried about Gas prices/octane--bump the ratio up--
Per 1 point increase in Comp Ratio you get 4% HP return....i.e.. 9:1 CR @ 100 hp and then bump to 10:1 =104 hp.
But in the long run all the little things add up and the reason i didnt go with the SC is because i like simplicity and want to take it on expedition type runs....
OK sorry for the long post
#49
And even the 2.0 is still below the SC RPM limit.
#51
Don't remember exactly where, i just remember when i was reserching everything for my SC that i heard the RPM limit on the m-62 supercharger is XXX which is a 1.X pulley. And if you get special bearings it cuts that almost in half.
#52
Not according to URD's website.
Originally Posted by URDUSA.com
Lately Underdog Racing Development has received many requests for even smaller pulleys with our unique reduced slip design. These pulleys are now available for sale, but they should be used with caution as they spin the supercharger past the manufacturer recommended limits.
kawazx636
10-06-2021 03:03 PM
LCE_Performance
10-01-2015 01:03 PM
4runnerFireman
09-29-2015 06:24 AM
