I was told my double cab looks lowered yesterday :( new OEM springs or? to restore it
Old 11-08-2011, 04:00 AM
Ilovemountains's Avatar
Question I was told my double cab looks lowered yesterday :( new OEM springs or? to restore it
I ran into a guy I used to run around with yesterday in his 03 d cab pre runner, its bone stock but has every bit of 2" of lift over mine. I never really looked at my springs but my rears are frowning and my front end seems to hit the bump stops quite often! I was going to order some Bilstein HD's for it this morning but want to get some thoughts on springs. I don’t want to lift it, well no more than say an inch over stock and I want to do it right so no blocks or spacers. Any suggestions short of buying new Toyota leafs and coils to install with my new shocks? Any suggestions on shocks over the Bilsteins? I installed a set of them on my dad’s 02 ext cab TRD and it made a huge difference over the stock fake Bilsteins that came on it. My truck has Tokico shocks now, Im sure the rears are shot, it sways pretty bad at highway speeds. I have 2” rear lift springs on my 88 from Downey Offroad, too bad they went under, they held their shape for years even with hauling and towing! Anyone know who made them for Downey?
Old 11-08-2011, 11:31 AM
mynameistommy510's Avatar
I'm not sure what rig you are talking about. Is your rig 2wd?
I own a 96 4runner 2wd and if i was looking into getting a slight lift, I would buy the 4wd coils online. It's new and cheaper by a long shot compared to the full OME.
I would look into doing something similar if I were you.
Old 11-08-2011, 11:44 AM
My truck is an 02 Tacoma double cab 4x4 TRD edition. My rear leaf springs are past being flat with the truck 100% unloaded, they look like they are frowning a little! I’m not sure about the front, it looks lower than my dad’s 02 ext. cab TRD that is bone stock except for the Bilstein HD shocks. I heard that the add a leaf springs will raise it up but make it ride pretty harsh, I like the way it rides but I seem to be on the bump stops on every dip in the road, I guess new shocks would slow the travel down down and might help keep it off the bump stops but to me, the springs are probably shot! When I get home this evening Im going to look online and see what I can come up with, I read that Eighbach makes lift springs for the front, but not the rear, I really don’t want to lift it, with say a 2 or 3” lift, I don’t need it as I don’t wheel it, I have my dirt bike for that fun, I just want to get the suspension travel back for the back roads of WV where I live!
Old 11-08-2011, 09:05 PM
dustrider's Avatar
I put 2.5 level lift spacers on the front and airbags in the rear with bilsteins
weak rear springs with just a little air works great
went from the droopydroor look to the prerunner look
way safer handling on the hiway too
Old 11-09-2011, 03:41 AM
This is my # 1 concern, right now at 70mph when you hit dips in the road, especially in a turn it wallows like a pig, my # 2 concern is how it looks, which looking at this picture, it looks fine, but next to a stock pre runner it looked low, my rear springs do look shot, they are not even flat, they are arched upwards like they are frowning! In this picture it looks OK though, perhaps its all in my head!
Attached Thumbnails I was told my double cab looks lowered yesterday :( new OEM springs or? to restore it-matts-taco-compressed.jpg
Old 11-09-2011, 06:01 AM
blake.nemitz's Avatar
wasnt there a recall on taco rear springs that were replaced free by the dealer due to sag and breaking leaves
Old 11-09-2011, 06:22 AM
not sure
That would be great!! I need to call about a recall on a balljoint too???
Old 11-09-2011, 07:22 AM
BMcEL's Avatar
I didn't see one for the rear leafs but there is one for the lower ball joints.
Vehicle Make / Model:
Model Year(s):
TOYOTA / 4RUNNER
2001-2002
TOYOTA / SEQUOIA
2002-2004
TOYOTA / TACOMA
2001-2004
TOYOTA / TUNDRA
2002-2004
NHTSA Campaign ID Number:
05V225000
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, DUE TO A MANUFACTURING ISSUE IN THE FRONT SUSPENSION LOWER BALL JOINT, THERE IS A POSSIBILITY THAT THE SURFACE OF THE BALL OF THE JOINT MAY HAVE BEEN SCRATCHED. THE BALL JOINT MAY EVENTUALLY EXPERIENCE EXCESSIVE WEAR AND LOOSENESS, RESULTING IN INCREASED STEERING EFFORT.
Consequence:
THE LOWER BALL JOINT MAY SEPARATE FROM THE KNUCKLE CAUSING LOSS OF STEERING CONTROL AND A CRASH COULD OCCUR.
Remedy:
DEALERS WILL REPLACE THE FRONT SUSPENSION LOWER BALL JOINTS FREE OF CHARGE. THE RECALL BEGAN ON JULY 5, 2005. OWNERS MAY CONTACT TOYOTA AT 1-800-331-4331.
Notes:
TOYOTA RECALL NO. 50J. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Old 11-10-2011, 01:06 PM
Let Us Hold Fast's Avatar
BMcEL,
Do you happen to know how long the recall is in effect? Do those things expire? Just bought an '04 taco DB cab earlier this year. The thing rides and handles perfectly, but it only has 110k miles on it. I guess I should look into getting the ball joints replaced while I can get it done for free, huh?
- Kyle
Old 11-10-2011, 01:27 PM
toyotaPmanager's Avatar
Recalls do not expire. only three ways you dont get it done free are #1 already been done. #2 vehicle has a salvage title or #3 which i have never seen happen with toyota is parts are no longer ava.
Old 03-05-2013, 06:45 PM
FireandIce's Avatar
I lifted my 2012 4door Tacoma at 1500 miles. I have a very nice set of leafs with an add-a-leaf, and my front system with a leveler in them. Would take $ 300 for all. In Denver. Shout if your interested.
ashersullivan88yota
01-18-2022 05:37 PM
jasonty
41
12-23-2018 01:00 PM
HaydenConQueso
07-12-2015 05:22 PM
horunner1x
07-10-2015 06:33 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: I was told my double cab looks lowered yesterday :( new OEM springs or? to restore it
