How often to you change your Oils?
I looked up the Transmission Fluid capacities (for 2002 Tacoma) and it
differs depending on which auto-transmission you have:
A340E Capacity 7.6 qts Drain Pan 1.7 qts (22% changed with drain and fill)
A340F Capacity 10.7 qts Drain Pan 2.1 qts (20% changed with drain and fill)
A44D Capacity 6.9 qts Drain Pan 2.5 qts (36% changed with drain and fill)
I'm not sure which one I have yet, I'll have to crawl under my truck again. But
at least this gives me an idea of how many times I'll need to drain and fill before
I sufficiently dilute the old transmission fluid.
Originally Posted by Sass69
Would it be fair to say that if you are switching to Synthetic that you MUST do a complete flush due to the incompatibility of the Reg vs. Synthetic?
