How much oil does your Yota lose/leak/burn/hide in mysterious places between changes?
Old 08-10-2004, 05:07 AM
98 Joes's Avatar
I'm dry again @ 189K. Mine started to leak a slight bit (2 or 3 drops overnight) from the rear main seal. After an oil change, it stopped leaking. I don't know why, I'm just glad it stopped
Old 08-10-2004, 07:31 AM
Gadget's Avatar
Originally Posted by VA_Yotaman
2000 miles since last change, down about a quart. It's been doing it for about 5 yrs. Never any smoke out of exhaust, puddles in driveway, or smell of oil burning. Oh well, it prob. likes a gulp of clean oil between changes anyway.
I have gone as much as 18,000 miles between changes and I have NEVER had to add any oil between changes on either of my Supercharged 4Runners.
My Maxima now needs about a half quart added between 15,000 mile oil changes now with 300,000 miles on the clock.
Gadget
Old 08-10-2004, 07:48 AM
Glenn's Avatar
My truck with the 22RE leaks a few drops from the front passenger side from time to time. Not sure if it is the timing cover or what. I rarely have to add oil between changes.
I run Amsoil and change once a year.
Old 08-10-2004, 09:50 AM
Flamedx4's Avatar
My '85 22RE wouldn't use a drop until right at 3000 miles, then it would start to use it quickly, perhaps a quart in the next 1000 miles. When it got to about a half quart low, the oil pressure would drop slightly at idle. This was always my reminder to change the oil. My father had exactly the same experience with his too. The 3.0 doesn't use any at all, and it has 212k on it!
Old 08-10-2004, 12:30 PM
  #25
Gabe's Avatar
I think this question pertains more to "how much does your 2nd gen 3.0 yota burn", rather than across all the generations. I researched the oil consumption and found on a 2nd gen, it is "normal" to lose a quart or more between changes. Granted I don't see anything "normal" about that but mine drinks oil too. Doesn't blow smoke or drip either. I notice I have to keep an eye on the level mostly when I go on trips that have high mountain passes and I am pushing the engine pretty hard. I think my next change I will swap to 10w 40, and will see what that does. Keep you posted ....
Old 08-10-2004, 06:22 PM
  #26
Goldrunner's Avatar
The 94 just started leaking a little at 165K, on a recent 1200 mile road trip I lost a little less than a quart. I always seem to have a little puddle under the engine after I park it, doesnt smoke though!
Old 08-10-2004, 06:25 PM
  #27
amusement's Avatar
My ol'95 3vze cam gaskets leaked at about 125K. Leaving little drops of oil here and there. Mostly on my tranmission. Argh! Had an ASE certified mechanic fix it.
Old 08-10-2004, 06:30 PM
  #28
camper4x4's Avatar
I traded my 9122re in with approx 350,000 and it had the same symptom. Would use a quart at least between oil changes.
Curt
Old 08-10-2004, 06:55 PM
  #29
CynicX's Avatar
None so far ... I hope it doesnt burn any ever....I owned a Ford Ranger, Chevrolet S-10, Jeep Wrangler, Subaru WRX and now this and none of them have ever used oil and I drove the Ranger, S-10, and almost the Wrangler above 200k miles....So I have my fingers crossed...
Old 08-16-2004, 07:42 PM
  #30
SD70MAC's Avatar
I go through about 1 quart each month, but I know where my oil goes...drip drip drip onto the ground from the rear main seal. Usually leaves a 3" diameter oil slick in the street each night.
Old 08-17-2004, 05:53 PM
  #31
weezy's Avatar
1 quart every 1500 miles. No leaks, smoking, or burning smell. Bad rings? Eh ... I JUST DONT CARE ANYMORE.
Old 08-21-2007, 07:57 AM
  #32
Shogun1011's Avatar
All of it!!
My 86 toyota leaks all of the oil!!! I put 4 quarts in...next thing i know...4 quarts on the garage floor!!! Oh yeah... does anyone know what the hole at the bottom of the oil pan is for?
lol..joking.
Actually, my yota does leak. I have to redo my timing cover install since i forgot to put some RTV on the top of the cover where it meets the headgasket. I also have a leak that drips down my bellhousing...i'm pretty sure it's not an oil pan leak...but possibly a shift lever seal leak?? or something like that. If anyone's got a pointer on that...let me know!!
~Shogun
Old 08-21-2007, 09:08 AM
  #33
keithguts's Avatar
I use 10w40 in my 95 runner, but it still uses 1 qt every 3K miles. I do see more being used on long trips as well. It has no leaking or any signs of burning.
Old 08-21-2007, 09:13 AM
  #34
old4runner's Avatar
leakage-the current yota less than a quart between oil changes. former yota's with bad oil pump o-rings about a quart every 250 miles.
Old 08-21-2007, 10:39 AM
  #35
Beartracker's Avatar
Maybe a few ounces in 8,000 miles. I have never used anything but Mobile 1
5W30. It's a 01 Tacoma, 2.7 and well taken care of.
[IMG][/IMG]
Old 08-21-2007, 10:40 AM
  #36
5W30. It's a 01 Tacoma, 2.7 and well taken care of, 90,000+ miles.
Old 08-21-2007, 11:40 AM
  #37
bob200587's Avatar
Wow..........who dug this thread up from 3 yrs ago!?
RaginAsian91
All Other Toyota Swaps
08-23-2015 10:27 AM
Yota.Jay
07-23-2015 08:08 PM
the1998sr5
07-16-2015 06:20 AM
Odin
07-15-2015 09:28 PM
Quick Reply: How much oil does your Yota lose/leak/burn/hide in mysterious places between changes?
