How many miles are on your supercharged 3.4
Old 06-26-2009, 05:31 PM
98.T4R's Avatar
just curious, for you s/c guys how many miles do you have on your engines and how long has the s/c been on?
Old 06-26-2009, 06:16 PM
Aznwolf118's Avatar
2002 sport edition
70K on motor 67k on s/c.
Old 06-26-2009, 08:05 PM
chris360hawks's Avatar
my buddies 99 taco has 180k on it and he s/c it and 160k. no 7th or anything! pulls hard as f***. about to s/c mine too, but with the 7th.
Old 06-26-2009, 08:42 PM
Hawkflyer's Avatar
mine has 144k on it, no 7th just stock.
Old 06-27-2009, 04:24 PM
98.T4R's Avatar
do you think a 3.4 could go 250,000 mi or more supercharged.
Old 06-27-2009, 04:30 PM
Matt16's Avatar
I was speaking to a buddy of mine last night. They took a s/c'd 3.4 to a dyno and analyzed the emmisions. He said with the s/c and no fuel mods, the engine runs very lean (like 16:1... normal is 14.7 to one). THis means that the engine is running hot- the fact that there are not a lot of people melting down their 3.4s into ingots means that those 3.4s are ridiculously overbuilt. Add the 7th injector and keep it cool and I can see 250K happening.
Hawkflyer's Avatar
If taken care of, I guess I don't see why not.
Old 06-27-2009, 04:38 PM
Hawkflyer's Avatar
Let me ask this,
I am new to the board, but not too green with forced induction. My Truck is S/C but stock. This 7th injector setup looks expensive. Why is no one running a rising rate fuel pressure regulator? I don't think it takes a whole lot more fuel to get those temps down.
Old 06-27-2009, 04:39 PM
Hawkflyer's Avatar
Something like this-
http://www.cartech.net/fmu2020instruc.htm
Old 06-28-2009, 06:29 AM
akaphilly's Avatar
250,000 on 4runner. 100,000 on s/c no fuel mods.
Old 06-28-2009, 07:38 AM
skrassow's Avatar
Originally Posted by Hawkflyer
If I remember correctly the issue is that the stock injectors cannot keep up. They run at 100% and cannot supply the required fuel. So I dont think just raising the fuel pressure would help that. But Im not real certain on how that works.
I think what Matt16 posted hit the nail on the head. Im betting the owner of that truck had no clue how bad his truck was running. For all of the guys running without fuel mods...do you have an AFR guage? Are you monitoring your engine in anyway? If so Im curious too see if anyone is running close to the AFR they should be (14.7 or 11.8 at WOT). Can you run without fuel mods? Sure. Will the 3.4 take it? most likely...for a while. But youll last a lot longer and get a lot more power out of it if you do the appropriate fuel mods. In the case with URDs 7th inj kit, not only can you get the AFR back where it should be but you have the ability to tune in a good deal more power (up to 40 HP more). Its definitely wroth the coin.
Old 06-28-2009, 04:11 PM
Mulkey's Avatar
170K on the engine and 165K on the S/C. No mods and the engine doesn't ping but I also rarely get the RPM's above 3800. Run's like it did when it was new. Also about to sell it so not really worried about it. lol Getting a V-8 4th Gen. It's like driving a bus but I am not off-road where size is a problem. 3 inches of lift on an 06 will take me everywhere I go in my 00.
Old 06-28-2009, 05:15 PM
Hawkflyer's Avatar
Thats what I wanted to hear. Any injector running at 100% duty cycle will pass more fuel at 60 PSI than at 35PSI for arguments sake. I wonder if I should start a new thread as I don't want to hijack this one. But I would really like to talk about this. I feel that there is more than one way to skin this cat!
Old 06-28-2009, 08:07 PM
skrassow's Avatar
Well it doesnt take too long before this stuff gets over my head! But go ahead and start a new thread, it will probably get pretty deep pretty quick. If you are real curious then I would email Gadget at URD and let him know what you are thinking and ask his opinion. He is an honest guy and isnt going to just try and sell you his product. He will give you a straight forward answer. If you do that, be sure and post up his reply. Id like to see it.
Old 06-28-2009, 08:49 PM
okie81's Avatar
90k total with 30k on the S/C
Originally Posted by Buhundred
I think fuel mods are a MUST if you supercharge. I would also check the compression.
They aren't a must, but are a good addition to an already proficient system.
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
coleypull15
11-03-2015 07:41 AM
mengquis
07-13-2015 10:39 AM
94whiterunner
07-12-2015 07:15 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: How many miles are on your supercharged 3.4
