How many miles do you get per tank?
if i sqeeze it to the last drop i get about 300 a tank, I have ISR and Deck plate and have larger tires(32s). I'm not too shy about steppin on it either. When i drive it until the empty light comes on, im usually at around 230-250mi range. Im sure the off ratio that my tires cause to read less milege so im not too mad but gas prices are high.
Originally Posted by casey
my best ever was 425, but that was nearly bone dry, and on the way to AZ. and it was a bit off due to an incorrect speedo/odometer reading.
now with 33s and 4.88's its absolutely right on and im averaging 300-320 per tank.
but this is on my 2.7 5 speed.
-Casey
-Casey
#26
I was getting 275-285 with a mix of hwy/city and 265/70/16s. After moving to 265/75/16s I am now getting 250-260. I also installed a new Flowmaster muffler about the same time and tend to run the RPMs up a bit higher now due to the the sweet sound and increased flow. This is likely contributing to my decrease in mileage as well. I have the deck plate mod and an Amsoil filter as well.
#28
'99 4unner V6 4x4 5spd with 32's and 4.30 gears
I get about 180-190 miles per tank (1/4 tank left) at about 75-80mph, about 230 miles per tank if I slow down to around 60mph, and I recently got 185 miles on a tank (15mpg) pulling my pop up camper at about 60-65 mph. These are also uncorrected b/c I'm not really sure how fast I'm going b/c of the tire and gear change.
#32
I was getting about 210-220 miles per tank with 33's and stock 4.56 gearing with average speed at 65-70mph. I changed my rear diff oil to 75/90w synthetic and now it's about roughly 240 miles at 65-70 mph. I still have to change my transmission fluid to Redline MT90 it will likely improve a little more.
#33
I get a little over 400 miles/tank. That's a best guess estimation as I have no working odometer at the moment. However, that is based on a mere 10mpg, which is something else that hasn't been verified in quite a while. So I guess, I don't know how many miles I get to a tank
#34
skoti89
09-11-2015 07:46 AM
Poncho0206
07-10-2015 06:21 PM
