Old 03-30-2016, 01:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Engine Guides
Print Wikipost
How to install a block heater (with pics)
Old 07-11-2010, 06:46 AM
noneckrex's Avatar
i found a freeze plug heater but i am having a hard time figuring out which size I need. O'Reilly's Auto Parts offers a 35mm plug but when i find it somewhere else online that site will say that the 35mm is not the write size for my 97 4Runner... need some help here. just need to know what size i need. thanks
Old 10-10-2017, 01:25 PM
Brody M. Wallace's Avatar
block heater questions
Originally Posted by Canadian Bacon
So I looked around the web and couldn't find anything good about installing block heater. I finally installed mine today, so I decided to take some pics.
Here's what I did.
I have a 1999 4runner Ltd 5vze. Don't know if this will be the same with the 2.7L
1. Jack up the front of the truck (at least get the front left tire off the ground which is what I did)
2. Pop off tire
3. This is optional, but I took off the front skid plate to have proper access to the radiator drain plug. It's plastic and I didn't want to strip it.
4. Drain the Rad
5. Take off the mud cover in the wheel well
6. Now you need to pop off your most rear frost plug. I did this using about 14 inches of 3/8 drive extension and a 2lb ball peen. give it a few good blows on one edge of the plug so that it comes out crooked instead of falling into your block.
7. Once you have the plug unseated, get some pliers to yank it out.
8. Now you can just put the plug in and tighten the screw, but I put some aviation silicone on around the edges because I heard that the plugs have a tendency to leak. If you use silicone or gasket maker, obviously let it dry before you start the engine, and make sure it has a high enough temperature rating.
9. Route your wire to your front grill. I used zap straps to secure the wire.
10. Put everything back together.
11. Refill your coolant. The whole system will take about 11 liters, so get 3 or 4 jugs.
Now you can keep your block toasty during those cold winter months
Attachment 185105
Attachment 185106
Attachment 185107
Attachment 185108
Attachment 185109
Attachment 185110
Attachment 185111
Hey I am new to the forum and am having trouble getting my block heater in
What position did you have the heating element facing? 6oclock?
I tried to put mine in at 6oclock and the top didnt seat properly (o ring popped out)
Is your heater flush with the frost plug hole or is the heater slightly raised (outside the hole)?
Any other recommendations in getting this in with ease?
thanks, brody
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
kcaudill
07-20-2015 12:06 PM
jon.r
07-11-2015 03:34 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: How to install a block heater (with pics)
