How do I replace an upper ball joint boot on 3rd gen?
Old 07-06-2006, 07:50 PM
soljah's Avatar
How do I replace an upper ball joint boot on a 3rd gen (Toyota part#43324-39015) ? How would I know its only the boot that needs to be replaced and not the complete upper ball joint?
After installing the OME/tundra lift, I have noticed my upper ball joints on both side are leaking. The lift has only been on for two weeks. I made a mistake and installed two spacers on each side. I just removed a spacer from each side to lessen the problem until I get my front limit straps on. I have never replaced a upper ball joint before and dont know how to test if the upper ball joint is now bad.
Any help would be greatly appreciated.
Old 07-06-2006, 07:54 PM
Localmotion's Avatar
I dont think you can replace just the upper boots. I havent heard of the upper ball joints going bad due to the tundra lift.
Old 07-06-2006, 08:11 PM
Tanto's Avatar
He did say that he put two spacers in, so I'm thinking that that's what got him. I ran the lift just fine with only one, but I did notice my UBJ was kinda tweaked. If it rattles or seems to bind during movement, you need to replace it.
Old 07-06-2006, 08:15 PM
soljah's Avatar
The information I found about just replacing an upper ball joint boot came from this thread:
https://www.yotatech.com/forums/show...per+ball+joint
Old 07-06-2006, 08:22 PM
ahh gotcha!
thanks for the info, sorry I dont have any answers.
Old 07-06-2006, 08:28 PM
Tanto's Avatar
So you're got it covered? The link in that thread didn't work for me.
Old 04-26-2016, 12:31 AM
jgowan75's Avatar
Does the upper ball joint get pressed in the spindle or the control arm?
Old 04-26-2016, 02:37 AM
KZN185W's Avatar
The UBJ is pressed into the spindle
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
lledwod
08-30-2016 01:03 PM
tpd143
07-07-2015 09:06 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: How do I replace an upper ball joint boot on 3rd gen?
