Horrible Gas Smell - New VC Gasket, PCV, Plugs, and Plug Wires
Old 10-02-2012, 07:40 PM
thrice1825's Avatar
Here's my sad embarassing story:
I replaced my valve cover gasket (passenger side), replaced the spark plugs, plug wires and PCV. In doing so I also used new gaskets for the throttle body and air intake.
I went to start the car up and it will start but smells like gas...it's horrendously strong and shakes like it's misfiring.
Can anyone give me advice on where to even begin to look?
Old 10-03-2012, 01:50 AM
totally a bro
Staff
vital22re's Avatar
did you plug in the coil packs? did you properly route the 3 spark plug wires? did you use the proper spark plugs? did you plug in the tps? Did you plug in the vacuum hose under the throttle body? etc... etc... etc...
Old 10-03-2012, 05:15 AM
thrice1825's Avatar
I think you may have saved my bacon.
I routed from
cylinder 5 to 2
cylinder 3 to 4
cylinder 1 to 6
From the sounds of it, it should be routed from
cylinder 5 to 2
cylinder 3 to 6
cylinder 1 to 4
Does that sound correct? Would that cause the toxic gas smell?
Old 10-03-2012, 08:18 AM
TheDurk's Avatar
I routed from
cylinder 5 to 2
cylinder 3 to 4
cylinder 1 to 6
cylinder 5 to 2
cylinder 3 to 6
cylinder 1 to 4
Oh yeah. And option #2 is correct. There is always a difference of three between opposite cylinders on this motor. That's how I remember it.
Old 10-10-2012, 06:19 PM
thrice1825's Avatar
That's a good way to remember!
For anyone in the future who is having the same issue, the cause was the spark plug wires. After making the corrections listed above the smell disappeared and the car ran great. Thanks for all the help everyone.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
steve miller
10-10-2015 01:40 AM
smiley52
07-11-2015 05:16 AM
bryan34w
07-06-2015 05:53 PM
toyota32
07-06-2015 05:42 PM
Quick Reply: Horrible Gas Smell - New VC Gasket, PCV, Plugs, and Plug Wires
