High RPM Vibration
High RPM Vibration
1999 3.4 Auto 4Runner. 50k on Engine, 200k on everything else.
I am getting nasty RPM based front end vibration that starts at 3.5k and gets progressively worse until it peaks at 4.5-4.7K then it usually shifts. I just swapped a new motor in and everything seems to be secure. Motor mounts and exhaust are all tight, and i marked every bolt on the flexplate/spacers so the weight should be dead on.
I just took it out and the vibration was so bad that it started to rattle the dash before it downshifted. Its pretty much narrowed down to flexplate for me, but i pulled the cover and everything looks fine... help!
