High idle switch anyone ?
Old 12-10-2009, 01:10 PM
FogRunner's Avatar
Recently I was sitting for a while with the inverter running several lights and noticed the battery voltage was going down. If I reved the engine up to around 1200-1300rpm the alternator would put out almost full output and keep up with the load.
So this gave me an idea, why not put a high idle switch on the 4runner.
Most all of the public service vehicles have them so they can idle the engine up for better engine cooling, more alternator output, and much better cooling from the A/C. So after reading the FSM for a bit I realized if I could trick to engine to think its not fully warmed up (but not cold) I could make it idle up.
So I cut the wire to the engine temp sensor and put a 10K variable resistor in line with the temp sensor. I then plugged in the ODB-II scanner and once the engine was fully warm I started to turn up the resitor and watching the engine temp on the scanner. As I turned up the resistance the engine idled up to around 1300 rpm, with the computer thinking that the engine was around 135 deg. Any lower than 120-125 F the engine will go into open loop and use more fuel.
But as long as you make the computer thing its over 125F it will go into closed loop and not adjust the fuel trim, all it will do is just idle the engine faster. After I found the setting on the resistor to equal 135 F I took it out, measured it and put a normal resistor with a switch that will put it in line.
So now if I want to sit with the inverter on, make the A/C keep me cool or run the winch, I flip the switch and it idles up to 1300 and stays there all day long.
Old 12-10-2009, 04:12 PM
cpizzle42's Avatar
wow that is awesome! I will be doing this mod once I have a winch.
Old 05-04-2012, 02:32 PM
EntradaTaco's Avatar
What size resister did you wind up using?
Old 08-23-2013, 08:40 PM
Snowheeler's Avatar
Fog, did you end up doing a write-up on this? I think this is something my battery would appreciate.
Old 03-23-2015, 04:23 AM
nickxrunner's Avatar
Old Thread revival
Has anyone done this? Im looking for a write up to install some sort of idle up switch such as this one. Any help would be greatly appreciated.
Old 03-24-2015, 04:30 AM
Really some help here guys...
Old 03-24-2015, 04:43 AM
JasonYota's Avatar
He explained it in the 1st post. Not sure what else you need. Plus he might not be around anymore
Old 03-24-2015, 08:30 AM
vasinvictor's Avatar
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
kcaudill
07-20-2015 12:06 PM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: High idle switch anyone ?
