help! Rear View Mirror Loose
Old 03-01-2003, 03:36 PM
AznStyle's Avatar
Question help! Rear View Mirror Loose
ok my rear view mirror shakes like crazy it is very loose. It gives me a headache just looking at it.. is there a way to tighten it.. any suggestions... It wiggles at the piece that connects the mirror to that console piece... I have a '01 limited 4runner
Old 03-03-2003, 05:53 AM
Erc
Erc's Avatar
If the assembly itself is loose, here’s what you’ll have to do:
All the bolts that hold the mirror in place are hidden. There's a plastic piece that pops out (it’s on the console right by the mirror). Pop that piece out. I don’t remember exactly, but I think it will expose one bolt. Pop out the clear plastic (glass) from the console with a thin screwdriver. You will see on big bolt securing the console in place. Remove the bolt and slide console toward the back and down. This will expose mirror assembly, which is held in place by 3 bolts. Tighten all the bolts and reverse steps to put console back in.
Old 03-03-2003, 07:23 PM
AznStyle's Avatar
thanx i fixed it... it didnt have anything to do with the screws there are two aligator mouth pieces on the sides of this medal thing and they needed to be widened so the thing holding the screw would stay in place... thanx a lot i would have never looked at that piece if it wasnt for you.... If anyone is having the same problem feel free to email me and i will help you through this process
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
lledwod
08-30-2016 01:03 PM
coreyedwards7611
01-16-2016 06:38 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: help! Rear View Mirror Loose
