View Poll Results: What combo should I go with?
Polished Wheel with Polished Beadlock
10
16.67%
Polished Wheel with Blue Beadlock
7
11.67%
Polished Wheel with Black Beadlock
1.67%
Med Grey PC'd wheel with Polished Beadlock
1.67%
Med Grey PC'd wheel with Blue Beadlock
3.33%
Med Grey PC'd wheel with Black Beadlock
5.00%
Black PC'd wheel with Polished Beadlock
13.33%
Black PC'd wheel with Blue Beadlock
17
28.33%
Black PC'd wheel with Black Beadlock
11
18.33%
Voters: 60. You may not vote on this poll
Help me with my beadlock and wheel color combo.
#41
I used an allow steel bolt, 145,000 psi minimum tensile strength and put them on with hardened washers between then and the ring. I did copy the idea from Rockstomper as well. I do plan on hanging onto the Grade 8 bolts (150Kpsi) that Champion used in case I start seeing problems on the trail. And the bolts are only torqued to 10-15 ft-lbs, I'm running 10 on mine.
#42
Roger are those zinc plated? I need something that will resist rusting somewhat.
Looking at these for zinc-plated:
http://www.mcmaster.com/param/asp/PS...MainWidth=1455
Or these for stainless:
This is what I have now (will be returning I guess):
#45
Originally Posted by Sludge
Cebby what about black pearl for your rims. I was just talking about painting my rims the other day. I was thinking either black pearl or just black.
#46
Originally Posted by 4Crawler
I used the zinc plated steel for the lock ring. I used stainless bolts on the inside of the wheel to replace the fake aluminum rivets, just for a better appearance.
#47
Well, I've had a change of heart. I saw a pristine 2nd Gen 4Runner (stocker) running down the road and loved the look of the stock silver alloys on the rig. I picked up some silver wheel paint and I think we have a winner.
#50
Uh, do those IFS rims have the right backspaceing for a Toyota Streight Axle? Because we know that is where you are heading.
With all that V8 power you will destroy the IFS as Cheese did with just a 3.4
Did you get the FSM from the smut board? It's there.
#52
#54
Kind of a bummer...
I had wanted to use the flush mount valves for my wheels, but I can't fit the fill tube in due to the position of the lockring.
Plan B: Use angled valve stems. I bought the 45 degree units since the 90 degree ones would not allow the use of tire deflators and also making refilling pretty difficult.
I just hope these don't get ripped off out on the trail...
#56
The short version: Mounting a tire on a beadlock wheel is a piece of cake -> do it yourself!
The long version: Read on....
Oh Man...
So I'm driving to various places to see who will slip the bottom bead of my tire onto the rim so I can bolt the ring on. I've seen folks really wrestle with getting the tire on the rim, so I figured I'd pop down to my local tire shop.
Place I usually go has closed their doors - no longer in business.
Other place I'd normally try says they can't do a tire that big.
3rd place I go, the guy wants to charge me $20 because I didn't buy his crap Mile Maker tires - then he takes one look at it and says no way. What a putz - he actually did me a favor, but he's still a putz since he didn't realize it and was an a-hole about it.
Soooo.....
I go back to the office and look up tire spoons and all the various DIY hardware "needed" to do mount the tire.
I wasn't about to wait for tools to come in.....
I finally do a google search for mounting tires on beadlock wheels. I came a across this writeup that showed exactly what to do. Basically, put the wheel on the ground, pull the ring, put a little dish soap on the bead and slip it over the beadlock side. Then bolt her down.... I found that the supplied bolts were too short to get the ring started, so I ran down to the local hardware store and got (8) 1 1/2" long bolts (5/16-18) to get the rings pulled down a little so the supplied bolts (1 1/4" long) would reach. Then the torquing... 15 ft lbs per criss-cross pattern x 24....
Here's the finished product:
It measures 35" tall x 12" wide mounted. I will likely swap out the gold bolts for galvanized button head socket like Rogers.
Oh Man...
Soooo.....
#57
Wait until you need to remove the tires from your rims...now that's a pain in the butt. For my friend's swampers it was a heck of a lot easier putting them on than taking them off.
#58
yeah, but it takes forever.
and it sucks when you're doing it with a crappy torque wrench. i gotta invest in a good one for next time.
beadlocking toyota wheels...i like it
#59
He's some more wheel p0rn.... (battery died on the digital eariler)
You can see how the "rim protector" protects the lock ring in the last pic.
