H4 HID Conversion now no HI beam indicator??
Old 04-11-2010, 07:02 PM
MattHCT's Avatar
I just installed a H4 dual beam HID conversion kit on my 1996 Tacoma. No my HI heam indicator light on the dash doesn't work. Is that normal? I only have the drivers side hooked up now because the kit had 1 bad ballast. So one side is hooked up. I don't see that being the problem since they are separate, but I may be wrong? Could that be it? Thanks for any help.
Old 04-11-2010, 07:13 PM
4Crawler's Avatar
Sounds like the HID harness does not handle the switched-ground Toyota wiring properly:
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
- http://www.4crawler.com/4x4/CheapTri...shtml#TechInfo
Old 04-11-2010, 07:14 PM
GranVille-4crawler's Avatar
I have a h4 hid kit in my subi and the high beam lite comes on, check your connections
Old 04-11-2010, 07:16 PM
t4r505's Avatar
That is normal.
A lot of guys over on TTORA have the same thing happen with HIDs.
Most kits have the 35 watt ballasts. But the light comes on normally when it senses a bigger change in voltage. I am not quite sure how th plug and play kits do the high beams but I am pretty sure it is a mechanical movement of a shield or something like that.
I have a projector retrofit and a shield flips to go from lows to highs. there is no actual change in voltage.
You might want to consider a projector retrofit because those kits are notorious for blinding other drivers around you.
Old 04-11-2010, 07:29 PM
JWaldz's Avatar
I have an H4 Bi-Xenon kit as well and the way the plug and play wiring is for the kit, it only allows one of the stock connections to be plugged in. With this the computer thinks that one of the sides isn't connected and wont show when your high beams is on. Pretty common in some kits. Mine is that way and I lost the high beam indicator which I don't care cus I don't run my lights during the day most the time and I can definitely tell when the highs are on at night so I don't need an indicator. Here's an image of what my kit looks like
Notice ^^^ The stock plugs is not used
Old 04-11-2010, 08:06 PM
ISFast's Avatar
https://www.ddmtuning.com/support/in...mid=11&nav=0,1
Here you go! It may have something to do with the amp between the to ballast for the HI/LOW. There should be a total of 3 boxes. 2 are the light ballast the 3rd is the amp box is what they call it. Anyways with the other light not hooked up then it probably wont work or if you dont have the 3rd box it probably wont work. Have to down load this link and it is on a 97 4runner.
Old 10-11-2012, 11:50 AM
hrt4me's Avatar
thanks for the good info!
Old 11-29-2014, 08:01 PM
bj117's Avatar
One fix for high beam indicator not working after HID conversion
I found this thread looking for info on how to get my high beam indicator to work after installing a Kensun HID kit to my 1999 Mazda Miata. This installation leaves one headlight connector unused. I thought I'd post what seems to be working for me, similar to what some others have posted.
I used a 40 Ohm 100 W power resistor (about $4) to connect two of the headlight connector pins as shown in this album
https://www.yotatech.com/members/bj1...connector.html
The resistor remains cool after 10 minutes. I haven't tried it for longer yet. With a 100 W 4 Ohm resistor, the resistor gets too hot to the touch in just a few minutes.
Old 11-29-2014, 09:36 PM
RAD4Runner's Avatar
Originally Posted by bj117
I found this thread looking for info...
You'd want the highest resistance that allows HB indicator to work consistently, then calculate power (watts) rating required. If the 40-ohm resistor makes HB indicator light up enuf for u, that's good. 100-watt rating is more than enough. Just make sure resistor gets enough ventilation And is not near anything that could melt or is flammable.
live4soccer7
05-11-2016 06:52 PM
clok
11-19-2015 01:09 PM
charlie_fong
09-27-2015 10:06 PM
clok
09-21-2015 08:18 PM
runnermedic
13
09-21-2015 05:20 PM
Quick Reply: H4 HID Conversion now no HI beam indicator??
