Gulf States Alarm???????
Old 07-15-2008, 04:15 PM
dairyjato's Avatar
my 98 4runner has a optional?? i guess, gulf states alarm. is there any way to disconnect or turn off and the truck still run. b/c you cannot start after battery is disconnected with out resetting the alarm. i dont use the alarm. any info on this "gulf states" alarm would be great thanks
Old 07-15-2008, 04:58 PM
corax's Avatar
is it just an aftermarket alarm? if so, find the starter disable relay, take it out and reconnect the factory wires which were to cut to install it.
should look something like this and be tied into one of the thick wires coming down from the ignition switch
this is how it'll be wired, just reconnect the factory wires
Old 07-15-2008, 05:06 PM
scuba's Avatar
All i know about this so called gulf states, is that they put a BS 1500 dollar markup on the toyotas here at the dealerships in texas/ gulf states.
thus being the reason why im not driving a new Tacoma.
Im sure theres a way, someone else will prolly chime in.
Ill get off my soap box now
Old 07-15-2008, 05:51 PM
rjaudi's Avatar
Is this the rs3000 alarm. I cant imagine a dealer installing an aftermarket alarm when there is a perfectly good factory accesory available. Look under the driver seat and see if an electonic box is zip tied down there.
Old 07-15-2008, 06:32 PM
rjaudi's Avatar
Just looked it up yours is the securikey+ alarm system built by audiovox.
This may interest you:
http://www.tacomaterritory.com/wiki/index.php/Securikey
Old 07-16-2008, 02:57 AM
dairyjato's Avatar
rjaudi, thank you so mush for the info that is what i was looking for thanks again
TheBFA
02-15-2020 06:55 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
Cycles
09-29-2015 06:37 AM
myotherrideisayoshi
09-29-2015 05:41 AM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Gulf States Alarm???????
