Grease or lube throwout bearing?
Old 03-09-2004, 12:50 PM
Albuquerque Jim's Avatar
Originally Posted by Chuki
my 82 and my 4-runner did this when I bought it.... Off the clutch pedal I would geta very light chirping, push clutch in went away.... What fixed mine was just adjust my clutch pedal. So that I had a slight bit more of freeplay.... I assumed mine was just barely touching the fins, giving it a chirp noise. Push the clutch pedal in, and the throw out bearing is mashed up against the fins.
My Runner did this, and I just adjusted it a tad and voila no more chirping.
You are the man!
I have been living with the "chirping" since I put a new clutch in in August 03. I figured it was either the front bearing or the TOB (even though I replaced it). I adjusted my clutch today (I never even looked for the adjustment before) and WHALA! My little birdie is gone !
Old 03-09-2004, 02:52 PM
Scofco's Avatar
How do you adjust the clutch?
I am having the same discussion over this problem in another thread. Mine just started chirping, and it's driving me nuts.
Old 03-09-2004, 03:39 PM
On my 3rd gen it's adjustable where the shaft for the slave cylinder connects to the clutch pedal.
Old 03-15-2004, 09:01 PM
Short lived excitement but new found joy
I should have posted sooner, but the chirping came back almost as quickly as it was eliminated.
However, today I was messing around under the truck with it running in Neutral (when mine chirped) and I grabbed the clutch fork and gave it a wiggle. This is the source of my chirp! I took the 2 bolts out of the slave cylinder and yep, metal to metal. Is there supposed to be a bushing in there? I think so, I will have to check with the dealer tomorrow. But anyways, I was looking for something to use as a bushing and I tried a valve stem cap and voila! it fits. This is probably a short term fix, I don't think a valve stem cap is rated for the wear of a slave cylinder bushing, but the chirping is gone! That chirping is sort of like chinese water torture.
Old 03-15-2004, 10:56 PM
  #25
VolcomTacoma's Avatar
I adjusted my clutch pedal a little and the chirping is mostly gone when the clutch pedal is not pushed when in neutral at idle. It seems like the 1-2 shift is a little smoother now. I'm thinking there was a little play or something before. Let us know if you find out about the bushing.
Old 03-16-2004, 03:52 PM
  #26
keisur's Avatar
Originally Posted by Albuquerque Jim
I should have posted sooner, but the chirping came back almost as quickly as it was eliminated..
I actually should have posted before you wasted your time trying this. I gave that a shot a couple years ago and it came back too.
Old 03-16-2004, 03:54 PM
  #27
keisur's Avatar
I don't think so. I just took some high pressure grease and smudged it where they contact. that isn't the source of my tweety bird. But I still haven't heard it since the flooding.
Old 03-16-2004, 04:14 PM
  #28
I stopped at the dealership today and there is no bushing for it. So I stopped at Autozone and bought a vaccum hose cap that fits perfectly...No more birdie. I almost forgot how quiet it is supposed to be.
Old 03-16-2004, 04:15 PM
  #29
keisur's Avatar
I hope you bought alot of them. I can't see it lasting very long being constantly smashed betweent the slave rod and the fork and rotating on it.
Old 03-16-2004, 05:56 PM
  #30
Thats funny cause after a few water crossings the chirping went away on mine for a day. Water must help lubricate something I guess.
Old 09-03-2015, 05:38 PM
  #31
RickyRick's Avatar
The only access hole in the bell housing I kno of is tward the bottom of the houseing im just not sure what u mean the fork is going threw I want to try what you are talking about but im not sure exactley how to do .any way u could explain for a dummy lol. I know there is like a rubber squar at bottom of bell housing that I can pop out and it will give me access into bottom of the bell housing is that the whole your talking about and were do I spray the greese lol. Could u try to help me understand please lol. By the way its my throw out barring cherping. It does it when the clutch is all the way out but if I just barley push on it at all it stops.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Grease or lube throwout bearing?
