Go with 15x8 or 16x8 for 1999 4x4?
Old 04-25-2004, 05:03 PM
baileymoto's Avatar
going to be purchasing a wheel/tire package for a 1999 4x4 this week. what would you go with for wheel size? any reason to go with 16" wheels other than 15" not fitting on the newer models? what year did toyota switch to bigger brakes not allowing a 15" wheel?
Old 04-25-2004, 05:10 PM
waskillywabbit's Avatar
Talking Looks or cost
15" is cheaper obviously rim and tire wise, but I think 16" looks better so that is what I changed to
Old 04-25-2004, 07:09 PM
Nitro Hotpants's Avatar
it depends on what you have on there right now from the factory, if you have 16's now, that is your only choice. 15's will most likely NOT fit if you have the big brakes. but if you have 15's stock from the factory then i would say stick with them, i like the look of smaller wheels and bigger tires, plus tires are cheaper for 15's like Brian said.
-Casey
Old 04-25-2004, 07:28 PM
SAStoy's Avatar
If you had 16s stock, chances are only 16's will bolt back up. On 4x Runners I know that the brakes are substantially larger than the 2x and will only allow a 16 inch wheel to clear the brakes.
itzmywife's
07-23-2015 08:32 AM
yourrealdad
07-21-2015 11:13 AM
Yotoder865
07-09-2015 07:51 PM
cyclist231
07-07-2015 12:56 PM
Quick Reply: Go with 15x8 or 16x8 for 1999 4x4?
