Gauge and dash backlighting
#81
You could check these out: http://www.oznium.com/led-dome
They come with a whole bunch of different connecters:
I *believe* one of those are ours... anyone concur?
#82
They are direct replacements, I just don't know which bulb style is up in the map/dome/cargo lights. The connectors just plug into the LED square, "bulb" goes directly into normal spot, and you replace the plastic cover.
check out the "more photos" and it shows they are direct replacements
#83
Thanks Texas_Ace, I haven't taken my dome light apart in awhile so I wasn't sure. Wonder how hard it would be to get these to fit up there....
o just fyi, this is a place to get OEM style switches too (http://www.oznium.com/gsw-45) I'm going to order some over winter break.
#84
#86
#88
here are some pics of my LED conversion. i just went green again since i like green, but now it's REALLY green and not that yellow/green that came stock. i still have to get the A/C, ECT, Rear Window, and rear defrost changed over with the nano bulbs. my clock doesn't work and you might notice the rear defrost isn't lit in the pics, burned out bulb and i dont feel like replacing in the winter.
just a note, the gauge cluster turned out fine but i'm going to try some other bulbs as suggested earlier for the heat controls and probably for the inclinometer (since you can't hardly see the altimeter) because of hot spots and lack of disspersion in other spots (corners of heat controls and "P" and "L" on the shift control. and the blue in the one shot of the passenger side power outlet is just the cell phone charger that's plugged in there, i think i'll have to fix that as well
on to the pics!
on to the pics!
#92
patrick
#94
Nice guys, the only thing that bothers me about the LED conversion is the hot spots... They aren't bad in the gauge cluster, but on the climate control they seem to stand out.
#99
#100
