Gauge and dash backlighting
#461
hope this helps https://www.yotatech.com/forums/f131.../#post51965945
#462
I made a whole thread on this subject. Dunno what year truck you're talking about.
Here ya go:
Here ya go:
#465
You guys seem to be really fighting poor quality LEDs, hot spots, fitment problems, etc. The solution for all of those issues is to abandon the plug and play bulb idea and instead use an LED ribbon around the gauges. The result is hotspot-free beautiful gauge illumination.
Option 1 is to use the LEDs meant for BMW angel eyes--the bulbs are spaced considerably closer together for a more uniform appearance.
But here is the best way (from a Toyota Supra site):
Wind an LED ribbon around the gauges and wire it to one of your abandoned bulb circuit board traces.
DSC_0005.jpg?t=1298964655
Those results are pretty stunning, no?
#471
#473
In case anyone needs to replace their HVAC heater air conditioner dash light bulbs in a 3rd gen (2002 SR5 in my case; verify yours is the same as mine), here is what I found. It took me a long time to find, so hopefully this helps someone out there. :
Toyota part number is 9001005126 . $8.16 per bulb at https://parts.toyota.com/p/Toyota_20...001005126.html
I found them cheaper at Toyotapartsdeal.com. Part number 90010-05126. $5.84 per bulb, with green covering over bulb.
https://www.toyotapartsdeal.com/oem/...tra2=&filter=()
Bourbonblues
12-15-2017 05:43 PM
Gone Fission
09-04-2015 12:18 PM
