gaskets for timing belt covers - rtv ok?
Old 11-02-2011, 12:39 PM
changosurf's Avatar
Im trying to finish up a timing belt change on a 98 v6 taco.
the timing cover gaskets are all worn out. I was thinking about ordering the original (adhesive?) gaskets from toyota, but Im wondering if I could save some money & just go ahead and use rtv sealant or something else? has anyone else tried this?
Old 11-03-2011, 05:23 PM
rworegon's Avatar
How about some sticky backed foam from the weatherization section of your local hardware store?
Old 11-03-2011, 08:25 PM
changosurf's Avatar
works for me, the cheaper&easier, the better...should it be ok to use that stuff in the engine compartment though? seeing as how its a harsh environment and all...
rock auto has a 'timing cover gasket kit' for around 15 bux; I was thinking about just going with that, but if the plain ole' weather seal from home depot works, I could just go use that stuff instead.
Old 11-04-2011, 03:52 PM
rworegon's Avatar
The stuff from Rock auto would work and less spendy too. I've used the Toyota foam and it does not look very special although it may be designed for higher temps and more resistance to oil, coolant, etc.
Old 11-21-2011, 02:10 PM
changosurf's Avatar
cool, I went with the gasket kit afterall. I got it from amazon instead of rockauto just cuz it was only slightly cheaper, same manufacturer though.
thanks for the help
06-01-2021 01:51 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: gaskets for timing belt covers - rtv ok?
