Gas mileage/larger tire equation
Old 05-22-2003, 02:10 PM
HaveBlue's Avatar
Noob question-
I searched for the answer becuase I remember seeing it posted before but I couldn't find it.
What is the equation to obtain the adjusted mileage with larger tires?
If I remember correctly, if your tires are 5% larger in diameter, then you need to add 5% to your average MPG, right? Or do I have that switched?
Thanks!
Old 05-22-2003, 02:16 PM
Darren's Avatar
You would add the dfference to your mileage. Not sure if that ends up being the same thing as adding it to the MPG's or not. Haven't thought through all that yet.
Calculator
Old 05-22-2003, 05:07 PM
HaveBlue's Avatar
Awesome! That's exactly what I was looking for. Thank you!
Old 05-22-2003, 05:37 PM
Victor's Avatar
https://www.yotatech.com/~corey/portal/portal.htm
Scroll down to the tire/wheel calculator. Use the actual heights of your tires. You'll have to go to the manufacturers' websites to find out what the actual height of your old and new tires are. For instance I went from a 31" tire (30.7) to a 265/75r16(31.8). That is about 3% difference
Charecter1
11-06-2023 10:08 AM
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
daddio
07-18-2015 10:20 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: Gas mileage/larger tire equation
