front end popping sound when turning
Old 08-06-2008, 06:07 PM
okie81's Avatar
Hey All, Got an issue with the runner that's been keeping me up at night. It's an 2001 4WD, no mods. I get a dull popping sound when I turn, sounds like it's coming from the front end. I notice it mostly at low speeds. Underneath, everything looks good, cv's are fine, ball joints appear good, sway bar/end links tight, etc. I have a rip in steering rack cover (passenger side), but that's about it. Could this be the problem (besides the obvious)? If not, what areas should I concentrate on? thanks!
Old 08-06-2008, 07:28 PM
98runner210's Avatar
good luck, I have had one since I owned it. I replaced upper and lower ball joints with no change. From what I have read there are several things that could cause it in the 4Runners and most seem to just live with it.
Old 08-07-2008, 03:18 AM
crolison's Avatar
is it popping or a slight clicking?
It could be your cv's going out, even though they may look fine they could be somehow going bad.
Old 08-07-2008, 04:36 AM
tommytuttle's Avatar
Could it be something in the steering rack, build up of dust or something?
Old 08-07-2008, 05:46 AM
zlathim's Avatar
If the popping sound increases and decreases with speed, it is going to be related to the rotating mass. The rack is not part of the rotating mass and would therefore not be suspect.
What you are describing is typical of cv joints, but if the boots are intact, it is kind of hard to condemn them. It sounds like you have looked it over fairly well. If you jack up the front end and place on jackstands, you can spin the tires by hand and have a buddy turn the steering wheel (engine off) from side to side. If it makes the noise, it should be pretty easy to locate.
Good luck.
Old 09-30-2008, 11:39 AM
okie81's Avatar
Turns out it was the sway bar bushings after all. I took off the end links and the inside of the bushings were shot. They looked good from the outside, but fell apart when I took them off.
The sure fire giveaway was the popping sound ONLY during body lean (duh).
Addco kit is on order, thanks for the help.
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
truckmike26
10-26-2015 05:10 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: front end popping sound when turning
