Free FMU mod: How do I do it with a boost gauge hooked up?
Old 04-19-2005, 12:17 PM
rimpainter.com's Avatar
Question Free FMU mod: How do I do it with a boost gauge hooked up?
As I get closer to selling the 97 and getting my SC'r back from Magnuson, I am beginning to map my plan of attack. Here is an exerpt from Gadget's site:
Originally Posted by gadget
With the FPR hooked to the boost port it will react to boost pressure and increase the fuel pressure under boost at a perfect 1:1 ratio. This offsets the boost pressure differential that I discussed earlier and really does a good job of stabilizing the fuel pressure in relation to manifold or boost pressure. The funny thing is that all the other fuel injected engines I have toyed with has the FPR connected to a port that allows it to read and adjust the fuel pressure in relation to engine load (manifold pressure).
Here is the benefit with the TRD supercharger. Like I explained earlier, as the manifold pressure increases in boost it will restrict fuel flow from the injectors. By reconnecting the FPR to the boost port you prevent this problem and it will give you 6-7 PSI of extra fuel pressure at max boost that you did not have before. Many people with the dreaded pining problem have tried this and it has in some cases eliminated the high gear, low RPM ping. All have reported an improvement.
I already have the boost gauge installed in my rig, and I already know that it plugs into the port that gadget is speaking of in his article. So I am wondering if there is any other way to get the free FMU mod to work. Does anyone know?
Old 04-19-2005, 12:31 PM
Gangus2006's Avatar
Cant you just T the boost line?
Old 04-19-2005, 12:47 PM
I thought of that, but won't that decrease the indicated reading on the boost gauge?
Also, the boost gauge has a pretty heavy duty threaded fitting with sealing tape, so I am not sure how I would properly "plug" it in with a T. You know what I mean?
Old 04-19-2005, 01:18 PM
Gangus2006's Avatar
You shouldnt get a decreased reading. Sport compact guys run boost controllers, stand alones, AND boost gauges off the same line all the time..
Old 04-19-2005, 01:23 PM
Well if that is the case, I should be able to figure something out. Thanks for the idea. Anybody else?
Old 04-19-2005, 03:31 PM
Albuquerque Jim's Avatar
Mine has a T as well.
Old 04-19-2005, 04:19 PM
blink's Avatar
you are okay'd tee'ed off. i tested it with the fmu and without... same readings..jsut gotta make sure the connections dont leak
Old 04-19-2005, 06:17 PM
midiwall's Avatar
T it dude! Mine is, and it works just supa!
Old 04-19-2005, 06:35 PM
Gangus2006's Avatar
You could use a "Y" fitting to prevent less obstruction too..
Old 04-19-2005, 07:12 PM
Anybody feel like posting a "T" part # or where I should be looking to get this T?
Old 04-19-2005, 09:17 PM
midiwall's Avatar
Christian, dude, you're working too hard!
Head to Schucks, Napa, AutoZone, etc. and look for the spinny-racks of things like plastic door panel fasteners, screws, vacuum T's, vacuum Y's, etc.
They come in various sizes, so bring a piece of the line with you.
Old 04-20-2005, 09:33 PM
blink's Avatar
lol...christian wait up for our lunch.... well have a shopping spree at autozones
Old 04-21-2005, 04:56 AM
Hey, I have to return to work foo! Don't hold me hostage after In N Out or I might have to get crazy!
Old 04-21-2005, 07:16 AM
loosehead's Avatar
So, I am away for while and next thing you know Christian is getting a S/C...Cool! It will be interesting to here how you like it.
Old 04-21-2005, 08:45 AM
blink's Avatar
yeah he got s/c envy when he drove my truck i think....heh j/k
Old 04-21-2005, 10:29 AM
midiwall's Avatar
We're all VERY happy for him!
Old 04-21-2005, 10:39 AM
My exhaust gaskets are cringing in anticipation Mark.
Old 04-22-2005, 08:08 PM
SLC Punk's Avatar
Yeah same here...
I just T'ed mine and the boost gauge works great!
RatOmeter
10-22-2015 03:17 PM
krimsonone
07-29-2015 11:53 AM
80Truck
07-24-2015 03:12 PM
88yodabasket
07-13-2015 01:32 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Free FMU mod: How do I do it with a boost gauge hooked up?
