Flex-a-lite fan
Re: Nice photos and good details!
Originally posted by Ryd
Thanks for posting your pics and notes Mark! It makes this mod much less threatening to those of us who wouldn't know where to start...
It looks like there's plenty of room to mount an additional transmission cooler and oil cooler as well. Where have folks installed these?
The fan is set to pull air, right?
There's a TON of room in there after pulling the mechanical and the shroud! If you add things like doing the ISR mod into the picture, then the engine compartment is really looking like an "oldie" - i.e., before All The Crap!
And yes, the FLX-210 is set to pull air from in front of the radiator. Though, in theory, since it's a DC fan, you can reverse the power leads and the fans will run backwards, but that doesn't imply that the motors, blades and bearings were _designed_ to run backwards.
Anyway... yes, the -210 is designed to bolt-on and go for our trucks.
Good luck!
FLX 210 vs. FLX 265 (Electric Fans)
When I go to Summit Racing and search for model-specific fans, the search comes up with the 265, not the 210. There is about a $100 difference between the two. My question for those that have done this is what is the difference? If the 265 is a kit that bolts right on, I don't mind spending the extra money if it's $100 more convenient.
Thanks.
Thanks.
Sorry, I meant the 675, not the 265...
Thanks.
Thanks.
save your money and use a volvo or taurus fan with variable speed controller
https://www.yotatech.com/forums/show...eed+controller
search for others that installed electric fans, there are cheaper and just as effective ways to do it without flex-a-lite
kawazx636
10-06-2021 03:03 PM
runnermedic
13
09-21-2015 05:20 PM
