Finally changed my fuel filter at 110,000...
Old 05-10-2011, 12:33 AM
raydouble's Avatar
Changed the fuel filter on the 01'.
110,000 miles, still had the OEM filter on it.
"Mud" was pouring out of it when I cut it in half.
Write up to follow.
Old 05-10-2011, 01:11 AM
scuba's Avatar
What did you cut it in half with? I wanted to cut my old one up but decided since I don't have a cutting tool that doesn't throw a lot of sparks it wouldn't be good to add spark to fuel...
Old 05-10-2011, 09:15 AM
raydouble's Avatar
Slow and steady with the hacksaw.
Put it in the vise and put the vise outside.
Old 05-10-2011, 09:21 AM
Bassmastry101's Avatar
Without the hands of a surgeon..sounds like it would be a nice fireball!
Old 05-10-2011, 09:48 AM
camo31_10.50's Avatar
pretty easy with a hacksaw guys lol makes me wanna change mine........
Old 05-10-2011, 09:54 AM
tunnelmotor99's Avatar
I changed mine last year @ 186000 miles, I think it was the original filter.
Old 05-10-2011, 10:14 AM
i take it as long as i check my fuel pressure, and it's within spec, then my fuel filter should be fine....correct?
says it's a lifetime part for my '92....can't really grasp that concept since gas does get dirty....
Old 05-10-2011, 11:28 AM
Evilmunkey's Avatar
Yeah mitchell states it's an in tank filter for my '02 so I'm guessing there is another in line. . ok scratch that they just don't list a procedure for it. . so I'm guessing it's along the frame like everyother SUV
Old 05-10-2011, 11:55 AM
blake.nemitz's Avatar
i changed my factory one at 180,000 and it was so clogged my motor started bogging aroung 3500
Old 05-10-2011, 11:57 AM
J2F42C's Avatar
Here is another link for the fuel filter change, but I am looking foward to Ray's DIY writeup since they are always great.....
https://www.yotatech.com/forums/f2/i...-today-109779/
Old 05-10-2011, 12:13 PM
SRT4runner's Avatar
How often is this supposed to be done? I'm at 110k with what looks to be the original one and the motor runs fine. It doesn't look like a fun job to do since there isn't much room to work with it under the truck.
Old 05-10-2011, 01:19 PM
MudHippy's Avatar
I replaced the original one on my 88 @ 207k miles. I noticed when I tipped it to drain the fuel from the fuel tank end of it into a can that the first half of what came out was gas. The last half was water. Both halves were rusty. Oddly though it was still doing a decent job, because the gas that came out of the other end(post-filtration side) was pretty damn clean.
Needless to say I noticed an improvement with the new filter. Not much, maybe +1-2 MPG and a bit more top end power.
Originally Posted by Evilmunkey
...ok scratch that they just don't list a procedure for it. . so I'm guessing it's along the frame like everyother SUV
Originally Posted by J2F42C
Here is another link for the fuel filter change...
Here's a thread about replacing the 2002 4Runner Fuel Filter.
Never..according to Toyota.
http://www.autoshop101.com/forms/h22.pdf
Old 05-10-2011, 02:23 PM
MaK92-4RnR's Avatar
it being the original filter sould come to no surprise.It is a "Life time part" and toyota states that it never needs replacing. therefore, not many replace it. I've replaced a few and nothing was wrong with them when they were replaced, and no noticable change was revealed.
Old 05-10-2011, 11:33 PM
raydouble's Avatar
Same mileage as the one above. :smile:
Mine was day and night.
Here is the write up, just finished it.
http://forum.ih8mud.com/95-gen-toyot...ml#post6615901
Old 05-11-2011, 04:18 AM
wormhole's Avatar
Why do they say the fuel filter is a lifetime part?
Old 05-11-2011, 04:43 AM
profuse007's Avatar
Purchased an OEM filter for my 2.7L several months ago but never gotten around to replace it. Might have to do it this weekend.
Old 05-11-2011, 11:03 AM
scottishb's Avatar
I'd like to add something! Instead of cranking the motor to get the fuel going, just turn the key to the on position 2 or 3 times.
Old 05-11-2011, 11:35 AM
raydouble's Avatar
It can definitely be done that way also. I don't really see a problem with running the starter for three seconds though.
Old 05-11-2011, 12:41 PM
Evilmunkey's Avatar
yeah I saw we had the Stock IN-Line F-Filter for 4Runners in stock at work, time to snag that siznit and change it out along w/ a good Fuel Induction Service :ninja:
Old 05-11-2011, 02:06 PM
MudHippy's Avatar
...because of the high capacity and quality of Toyota's filter.
https://www.yotatech.com/51719537-post12.html
Quick Reply: Finally changed my fuel filter at 110,000...
