Fake water pump??????
Old 03-02-2008, 07:29 AM
Dan.3's Avatar
Question Fake water pump??????
Hey eveyone. Going to be dropping in my 3.4 this up coming weekend. It just needs the fake water pump that the fan and pulleys hook up to. I know the toyota fake water pump/fan asselbly is the best way to go. But at around $300 i was wondering if anyone has ever used a new aftermarket fan assemly/fake water pump with the clutch fan hooked up to it. I know mt_goat is using an aftermarket assembly but he is also using an efan. I have thought about getting a used toyota assembly but my concern on both the used and aftermarket is the bearings. What I will probably end up doing is get the aftermarket and a cheap used one as a back up. Opinions???
Old 03-02-2008, 08:19 AM
Staff
DeathCougar's Avatar
I would stick with a new factory one, or a used factory one. I have heard horror stories of the casing on the aftermarket ones exploding becuase they are made of cheap pot metal instead of cast aluminum.
Besides that they go as cheap as possible when making those things...so that means the quality of the bearings is terrible too.
Old 03-02-2008, 11:10 AM
mt_goat's Avatar
You found an OEM one for only $300? I thought they were more than twice that. I'd go with the OEM for $300, and might also go with an e-fan to remove most of the stess on it.
Old 03-02-2008, 11:32 AM
Staff
Clutch and pulley (that includes the fan support bracket) - 3.4 liter - 3.4 liter 96-02 LIST: $485.77 COST: $344.61
From Toyotapartsales.com
Old 03-02-2008, 01:25 PM
MTL_4runner's Avatar
Get a new one from Toyota of Dallas or get used one out of a junkyard.
Do not use an aftermarket part for this application.
Old 03-02-2008, 02:50 PM
Dan.3's Avatar
thanks guys Im going to get a used one out of a junkyard then. Ill probably get two actually. Better safe than sorry. By the way I ment the 344 price. I could remember the exact figure so I just ball parked it.
Old 09-14-2009, 10:26 AM
89RUNNERFFD's Avatar
I just got a quote from the discount shop, $681.95 for a toyota part.
upongame619
08-01-2015 12:12 AM
TJWilly
07-31-2015 02:05 PM
jjrbus
07-19-2015 02:06 PM
Snort
07-19-2015 07:03 AM
Jonny246
07-12-2015 04:51 AM
Quick Reply: Fake water pump??????
