View Poll Results: What Exhaust Header Do You Recomend I Should Upgrade To?
LC Engineering
25
40.32%
Downey (from PP)
24
38.71%
Stock
7
11.29%
Other (please specify in a responce)
9.68%
Voters: 62. You may not vote on this poll
Which exhaust header should I get?
Old 01-07-2005, 02:49 PM
waskillywabbit's Avatar
I'm looking to put in a new header and go with a custom exhaust because my stock one is trashed anyway.
I know I want 2 1/4" pipe and a Flowmast 40 Dyna Flow so I don't rattle my teeth out, but have some good sound.
Should I go Thorley or LC? How much should I expect to pay for the whole thing?
What about a new cat?
Old 01-07-2005, 03:50 PM
aviator's Avatar
Hedman used to make a header for the 22r
I don't know the quality but hedman made a header for the 22r (i ordered it but never picked it up other things came up) I think it fits the 22re also. I remember it was supposed to be a plug n' play part with the rest of the stock exhaust system. you could check with them. As I recall it was pretty cheap price wise compared to downey et al. might be worth checking on. as for the cat if you're putting a new one in get a free flow cat it will be a lot better then the stock one. cheers Aviator
Old 01-07-2005, 07:54 PM
4Crawler's Avatar
I've had an LC header on my '85 for about 5 years now. It works well, no leaks, looks just like the day I installed it with the ceramic coating:
http://www.4crawler.com/4x4/CheapTri....shtml#Exhaust
Mine was made before they swapped to stainless steel, but even so it has not shown any rust (only rusty part is where I tried to use high-temp paint on the stock block-off plates):
Old 01-08-2005, 07:49 AM
I am definitely going LC header and perhaps even their exhaust setup too, since I don't have any spare parts just lying around for such.
I imagine my cat will be clogged as yours was as it looks pretty old, perhaps the original. Where did you pick up that aftermarket one you were talking about (Maremount)? Did it work out okay? How expensive is a new cat?
Most importantly, what did you do about a gasket?
I don't know why I bother asking stuff on YT anymore, I should just email you!!!
Old 01-08-2005, 08:22 AM
  #25
4Crawler's Avatar
Got the cat at a local auto parts store (Kragens as I recall). LC hes some decent cats as well, I think their's are welded flange type. The one I got was not welded (i.e. a loose flange) but I ended up welding the flanges to the cat and grinding the flange flat for a better seal. I ended up re-using the stock exhaust gasket, it had the better heat shield around the spark plug wires. I may finally change it out if I work on the engine again.
Old 06-07-2006, 04:33 AM
  #26
Yotaboy's Avatar
Ive got LC Engineering header on my 88 Runner. It rubs the frame and the cremic coating is poping off at the mounting flange. I just bought a crome Downey header for my 86 pick-up and had no problems so far.
Old 10-28-2006, 06:51 AM
  #27
toyotaoffroad91's Avatar
this is my downey cermic header. this pic was taken recently and i installed this header 3 years ago..its holdig up awsome, comes with all smog hookups to
Old 10-28-2006, 07:13 AM
  #28
04 Rocko Taco's Avatar
Holy thread revivals batman. This one never dies.
Old 11-04-2006, 03:30 PM
  #29
AH64ID's Avatar
I have had both Downey and LCE and the LCE is a better product, hands down.
I dont beleive in getting either of their exhaust systems. Its much cheaper to have a carsound (magnaflow) cat and muffler of your choice installed, and it fits tighter to the vehicle for more ground clerance.
alexcarey
10-14-2015 06:05 PM
voiddweller
09-28-2015 11:21 PM
Keithstoyota
09-27-2015 07:29 AM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Which exhaust header should I get?
