Engine whine when lights are turned on
Old 09-04-2012, 10:56 AM
RMSlayer's Avatar
Hello fellow Yota fans!
I have a 98 4runner SR5, and have been getting a whine under the hood when I turn on my lights. I thought it was potentially the a timing belt pulley going out, and it was 10k over on replacement, but after doing the t-belt, it still makes the whine(got the kit that had the water pump, t-stat, and all the pulleys). ???? Any thoughts or ideas on what to check would be greatly appreciated.
Old 09-04-2012, 11:35 AM
mastacox's Avatar
Sounds like it could be related to your alternator. When's the last time the belt was changed?
Old 09-04-2012, 12:55 PM
RMSlayer's Avatar
Belts were done recently, a few months ago. I took it by my buddies shop, who did the t-belt, he thinks it might be the alternator too. We put a stethoscope on the back by the bearing..... Sounded suspect. It is the OG alt, with 135k.
Old 09-17-2012, 06:17 AM
runnermedic's Avatar
alternator for sure
Old 09-19-2012, 06:00 PM
UKrunner's Avatar
Check your battery negative to chassis/body connection. My clamp came loose and if I turned on the lights or heater blower there was a whine.
Old 09-19-2012, 09:35 PM
x2468's Avatar
Is it like a shrill squeeling? if that's the case it's the alternator belt. Maybe it's a little out of spec. If it's not that high pitch then it could be the bearing.
Old 09-22-2012, 06:01 AM
RMSlayer's Avatar
It was a lower type of groaning. Replaced the alternator. All good now!
Thanks for all of the input guys!
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Engine whine when lights are turned on
