Engine and Tranny Swap (together)
Old 01-24-2013, 07:21 AM
@ftermath's Avatar
Old 01-24-2013, 11:41 AM
niall's Avatar
I think you'll need to seperate the transfer case off the back of the trans, but other than that and pulling the rad (more for it's own protection) I believe you can pull them up and out together.
Old 01-24-2013, 01:04 PM
@ftermath's Avatar
Old 01-25-2013, 05:13 AM
Texas_Ace's Avatar
You can in theory but you might have a problem getting the engine/tranny high enough with normal engine lifts.
Old 02-03-2013, 09:27 PM
johntnj's Avatar
I tried to get the engine and trans out in one piece on my 01 tacoma 4x4 and was a failure. The height of the truck and the lift of the normal engine crane make it impossible. There may be a trick to it but you will probably have less aggravation if you drop trans them lift engine
Old 02-04-2013, 05:59 AM
@ftermath's Avatar
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
coryc85
09-09-2015 06:24 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Engine and Tranny Swap (together)
