Old 03-30-2016, 02:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Engine Guides
Print Wikipost
Engine Oil for 3.4 v6
Old 10-21-2004, 06:11 PM
InFlames's Avatar
How many quarts are everyone puttin in their 3.4 4x4 tacoma engine WITH oil filter change. Mine takes a little over 5.5 quarts. What does everyone else use? also it says on the fill cap SAE - 5w-30 oil....but i use 10w-30 oil...is this ok? I live in south CA so it dosent see much freezing weather... thanks!
p.s i use castrol non synthetic gtx oil at 148k miles the engine dosent drip a drop or consume anything noticably...
Old 10-21-2004, 07:18 PM
rimpainter.com's Avatar
5.5 qts, 5-30 here. I think you could safely go down to 5-30.
Old 10-21-2004, 08:49 PM
boogyman's Avatar
Talking
i have a 2000 v6 4x4, and i use 5w-30 regular dino oil here in mid cal..
my rig usually takes about 6 quarts with oil change.
russell
Old 10-21-2004, 11:33 PM
ranma21's Avatar
96 runner sr5 0w30 amsoil series 2000, running just fine!!:
Old 10-22-2004, 07:36 AM
roger's Avatar
I use about 5.5 quarts with a filter change.
I doubt 10w30 will harm your engine, but 5w30 would be optimal. Might give you a slight boost in fuel economy too.
Old 10-22-2004, 07:47 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
A tad over 5.5 qts w/filter change (when don't you change the filter when doing an oil change?!?!?!) on my '00 V6 3.4L.
Old 10-22-2004, 08:15 AM
InFlames's Avatar
I was stating that I always change the oil filter with a Toyota oil filter every oil change. Some people go 10K on the same oil filter...i wouldnt!
Anyone else use 10w-30 in Cali?
Old 10-22-2004, 08:31 AM
SLC Punk's Avatar
I put in 6 quarts, after the filter has filled up, the oil level is just below the full mark.
Old 10-22-2004, 10:04 AM
snwbdr's Avatar
I use 5-30 but I go up to the snow a lot....but I have friends who are desert bunnies and some of them run 10w-30
Old 10-22-2004, 10:54 AM
VolcomTacoma's Avatar
I use 5W-30 in mine because that is what the manual says is preferred and will work for all climates. 10W-30 is recommended for temps above 0 degrees.
Old 07-04-2014, 02:31 PM
Jsweatt1987's Avatar
I use 0w-20 oil. It's recommended for toyota's. And I have a 99 tacoma 3.4L engine. And mine holds 6 qts.
Old 07-04-2014, 03:18 PM
hotlavaaaa's Avatar
Bumping a ten year old thread to add bad advice. Interesting.
The following users liked this post:
drum4jc2u (05-11-2021)
Old 07-12-2014, 09:50 AM
Arnezie's Avatar
Wrong wrong wrong
Old 07-12-2014, 02:54 PM
jbtvt's Avatar
It's a Jeep thing, we wouldn't understand
Old 07-12-2014, 06:05 PM
rworegon's Avatar
Unless you can prove up your statement about Toyota's revised oil recommendation for the 5VZ-FE to 0W-20 with an factual official Toyota document, we will use the document linked below to disprove your statement with the following: "ILSAC GF–4 SAE 0W–20: This oil has even better fuel efficiency and cold starting performance than 5W–20. Initial application for 0W–20 is in the 2006 model year 2AZ–FE engine and will be used in new engines to be developed."
The TSB can be found here:
http://www.matrixowners.com/tsb/TS-EG018-06.pdf
Old 07-12-2014, 08:22 PM
vasinvictor's Avatar
Again, a 10 year old thread bump by a misinformed soul. I think the important thing is just change your oil every now and then
Old 07-12-2014, 10:45 PM
wyoming9's Avatar
Red face
I think once in awhile is much better then now and then!!
Old 02-18-2018, 11:51 AM
socalbobby's Avatar
K&N for life
Old 02-18-2018, 11:54 AM
Originally Posted by socalbobby
K&N for life
be sure to check the post date before you reply. 🙄
smthwsn357
05-01-2024 07:28 AM
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Colington
03-08-2020 09:51 AM
Jdgarrison
10-01-2015 05:22 PM
Quick Reply: Engine Oil for 3.4 v6
