Electrical Problems!
Old 05-10-2018, 02:22 PM
richeaus's Avatar
I believe this is my first post on here since I bought my 98' Limited 4x4 4Runner 2 years ago. I am in a bit of a situation and not sure where else to turn. I grabbed a 2000 4Runner center console and cup holders to upgrade from my floppy radio bezel, climate control blocking ones. I installed the pieces and that went smoothly. When I went to start up the 4Runner, I have no power to any of my accessories, I cannot shift out of park, and my instrument cluster will only light up the airbag light and the battery light. The airbag light will go out like it should, but the battery light stays on. Now, ALL I did during the install was cut the tape off the harness for the back window and the ECT button. I checked already and did not cut into any wires and I was careful when working with them. I also relocated the RS3000 alarm sensor and light over towards the driver vent/ fog light switch area. I am pretty mechanically inclined and am taking classes to become an automotive technician. Sadly, I do not have access to my school's repair software and cannot get a wiring diagram. by accessories, I mean I have no power to anything inside the car besides power locks and headlights. I cannot turn the radio, climate control, windows (cabin or rear window or sunroof), or wipers or turn signals. I thought maybe I blew a fuse and I have checked them all as well as thought maybe the fuse panel "30A Power" maxi fuse may have blown. I replaced it to no avail. I also took my DVOM to the battery with the 4Runner running and it does not seem to be charging. I doubt it is alternator related as too many other items are messed up. Any ideas or help will be greatly appreciated as it is my daily driver!
Old 05-10-2018, 05:05 PM
akwheeler's Avatar
there is no reason to replace a fuse because it "may have blown" when you have a DVOM. check all of them for power being supplied to them and continuity through them (or power on both sides).
Old 05-10-2018, 05:10 PM
richeaus's Avatar
It is when it's an enclosed fuse and the wire I can see looks corroded. I don't usually throw parts at things. There was power on the contacts of the power fuse, but nothing to the fuses below it.
No worry, I fixed it anyways. I'm no sure what the issue was, but I put everything back to where it was and it started up normal. Weird electrical Gremlins.
Old 05-10-2018, 08:58 PM
fierohink's Avatar
First things first, do you still have your old parts? If so, restore to original and try to figure out what went wrong. If you restore to original and still have the issues then we can look at the wiring you disturbed or circuits that aren’t getting power. PM me an email addrsss because I think I have your EOD
Old 05-11-2018, 10:31 PM
RAD4Runner's Avatar
Originally Posted by richeaus
... took my DVOM to the battery with the 4Runner running and it does not seem to be charging...
What's criteria on your generation to tell whether its charging or not? It's 13.5 to 15.1V on earlier MoreFunners....
...Weird electrical Gremlins...
Glad you fixed it but until you find that gremlin, it's still hiding in there... Like mentioned above, inspect old parts, to help see what really happened.
Lazybummm
12-26-2002 02:46 AM
r2xj
7
11-27-2002 07:37 PM
MonkeyElvis
11-11-2002 03:50 AM
dhammeraudio
10-28-2002 11:19 AM
Quick Reply: Electrical Problems!
