EGR Superguard makes noise
Old 11-20-2003, 12:16 PM
Angry EGR Superguard makes noise
Ok, last night I installed my new EGR Superguard-3d Carbon Fiber bug deflector. On my way into work this morning, driving about 40-50mph, the deflector starts making a whistling noise. Almost like the noise when a side window is cracked open. Do they all do this? It's gonna drive me crazy if it gets even louder on the highway.
Old 11-20-2003, 12:22 PM
4RunnerFever's Avatar
Mine is quiet, but I usually drive with the windows up.
Old 11-20-2003, 12:27 PM
the noise is loud enough to hear when the windows are rolled up.
Old 11-20-2003, 12:34 PM
CLin9383's Avatar
really, i have the exact same one and there is no noise...
Old 11-20-2003, 12:36 PM
waskillywabbit's Avatar
EGR
Mine never makes a sound, but then again it does not have the carbon fiber texture either. I'll bet that is what is making the whistling.
Old 11-20-2003, 12:43 PM
Re: EGR
It's not textured. It's just a pattern in the plastic (clear plastic with a black pattern). As far as I can tell.
Old 11-20-2003, 12:52 PM
Re: Re: EGR
Maybe you do have a side window cracked and you don't know it. I would recheck the (4) screw fasteners and make sure that your shield is symmetrically installed across the front as you have some room to play with due to the slots for mounting. I would also check and make sure that somehow your guard is not bent out of symmetry from shipping and thus causing an irregular airflow over it.
If these don't fix it I would suggest turning up the radio real loud.
Old 11-20-2003, 01:06 PM
I'll look into that tonight after work... but, I'm pretty sure it's on there even, measured several times. It was really hard to install, so maybe I messed something up.
Old 11-20-2003, 01:11 PM
Hard to install???
Yours was hard to install? Mine had (4) screws that went through (4) little rubber washers and the EGR guard into (4) little inserts that you popped into (4) little places under the front of the hood. Took me all of about 2 minutes to install the whole kit and kaboodle.
Does yours look like this except it is carbon fiber?
Old 11-20-2003, 01:24 PM
heh, ya I was joking. har har? It looks exactly like yours except it's clear with the carbon fiber pattern.
I'll post a picture of it tonight.
Your truck rocks btw.
Old 11-20-2003, 01:26 PM
Worried
You had me worried there for a second dude. Talk about mechanically challenged! If you can brush your teeth without injuring yourself you can put on the EGR easily.
My rig is but beginning it's rockness, but thanks!
Old 11-20-2003, 02:13 PM
CLin9383's Avatar
Mine
Old 11-21-2003, 03:31 AM
Wish I could help more but my bugflector doesn't make a sound but my sunrooflector does whistle. I wonder if the EGR is redirecting the wind to some extent and that is causing your problem.
Have you tried reinstalling it just to see if it was a fluke? Also, I had to adjust my hood to get it to close properly.
Good Luck!!
Old 11-21-2003, 04:29 AM
AznSky's Avatar
does your bug guards have drainage holes at the bottom? My OEM does and they make loud whistling sounds when driving. So I taped up all the long holes and the whistling stopped.
Maybe you want to look into that.
Old 11-21-2003, 06:32 AM
ALBPM's Avatar
I have the EGR Carbon Fiber "like" guard and it made a lot of wind noise after I installed it. - I say carbon Fiber "like" because it is just a printed pattern on the back side of the guard.
I solved mine by adjusting the hood stops in the front. Just screw them out a bit more. This raises the front of the hood a bit and changes the airflow.
This was the fix for my 93 Runner's problem with the back hood rattling/flapping at high speed.
Old 11-21-2003, 08:25 AM
hey, thanks for the replys. It doesn't have any drainage holes but it does have a section on each side, above the lights, where it does not wrap under the hood. My guess is that is where the noise is coming from.
I will try to adjust the hood stops/latch this weekend and see if that helps.
Old 09-21-2017, 08:19 AM
Jason B's Avatar
Does anyone still have this eve carbon guard? I need one and they stopped making them.
Old 09-23-2017, 01:03 PM
ALBPM's Avatar
https://www.carid.com/2002-toyota-4r...-35069084.html
Then click on - Product Options.
Old 04-25-2018, 04:01 PM
Jason B's Avatar
Anyone still have?
Old 07-25-2018, 01:41 PM
Jason B's Avatar
Does anyone still have their EGR guard?
Quick Reply: EGR Superguard makes noise
