E-Locker Identification
Having a center differential will allow you to use 4wd on the street without binding things up. If you dont have a center diff and you drive on the street and make sharp turns, you can bind up your drivetrain and do some damage.
i think im gettin it...sorry guys.. so say its snowin and i want 4wd for the street i should put it in 4wd high and then press the button, but if im offroading or something just put it in 4wd h or low is this correct?
yea i know its in high gear now but to engage you push the button on the shifter and then if im on the road and making turns and stuff i should also press the center diff lock button
justdifferentials
Just Differentials
06-13-2022 07:40 PM
1uzRunner
63
11-10-2018 03:58 PM
zz_denis
09-06-2015 03:43 PM
