Dyno'ed the 22re!!!
Old 03-01-2007, 07:35 PM
  #61
s30devilz's Avatar
proper dyno tech
Well, I found out from the superflow manual that you should do all test in the gear that is closest to 1:1, but obviusly thier our safe speed limits to tires that don't always allow for this so the you have to adjust the dyno with you gear ratios to get a propper corection factor. If every one in his area dyno's in certain gears regardless of actual ratio probably only have half a clue of what they are doing or have the dyno's skewed to print numbers that are higher than actual to make thier stuff look better. Which is surpeisingly common.
JNapolitano
11-14-2019 07:46 PM
ia02
08-20-2015 11:04 AM
ChiefTetlow
08-10-2015 04:19 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Dyno'ed the 22re!!!
